Technical Help needed on 55 chevy!
Discussion in 'Traditional Hot Rods' started by Danny1610, Mar 27, 2026 at 5:25 AM.
  1. Danny1610
    Danny1610
    Hi all! I have a 1955 Chevy Bel Air and i just replaced all front bearings.
    Now it’s time to install wheel hubs on spindle.
    I saw in various forums that the correct way to instal and thighten the spindle nut is to thighten it to 12ft-lbs. and then loosen it and then again finger-thighten it. But it does not convince me… as on the Mechanical Shop Manual it says to thighten it at 33ft-lbs. and then back it off as much as it align with the hole for the spindle cotter pin…. Who I have to listen so?
    Danny
  2. oldolds
    oldolds
    I think it might change if you are using the original ball bearing or have converted it to roller bearings.
    Here is the procedure from the factory Service manual. Thanks to @squirrel.
    Johnny Gee and bob b. like this.
  3. Danny1610
    Danny1610
    Still have the factory original bearings.. bought them brand new
  4. Moriarity
    Moriarity
    SUPER MODERATOR
    yup, always trust the shop manual....
    Danny1610 likes this.
  5. squirrel
    Factory 55 manual applies to factory ball bearings, which run a bit tight.
    Later factory manual procedure for being looser applies to tapered roller bearings, that later cars used, which don't run as tight as ball bearings.
    Moriarity and Danny1610 like this.
