I am in Pendleton, OR with a leaky Wilwood 3/4" bore clutch master cylinder. It won't hold pressure. Need either a source for a replacement or a cross-over to something similar off the shelf. This has a 2 bolt vertical mounting pattern, built in reservoir. I'm At a Shucks/Oreillys in Pendleton. Thanks! -Brian 469.471.4929
BRIAN, I Use universal cups for brake systems in mine, which the older part stores might have, the one here in town has, I was thinking they were out of a tractor or 40 ford ft. brake cylinder. it will go out but will get you home
Brian, Same thing happened to my buddy at Louisville last weekend. Wildwood sold him one of their display models. But, anyway, he went to Jeg,s who had them in stock. Maybe a similar distributor closer to you?
The only thing that comes up in Pendleton is; Cl***ic Bodyworks 412 Southwest 11th Street, Pendleton, OR, 97801, phone: (541) 276-8732 Give them a call and see if they know of any guys in that area. If you can make it to Boise, sure to have something here.
A local guy named Dennis just gave me a lift to a local shop and then to a parts house called Baxter Auto Parts. Bought a 73 Datsun master cylinder and used the guts out of it to fix the Wilwood. Put it back on and some guys heading to Bonneville with a B/GMS Opel helped me bleed the clutch. Seems good now...about to get back on the road . Thanks guys for the help! -Brian
that is so awesome, not the fact the master went out, but that in such a small span of time the problem was solved with just the niceness of strangers. Rally on!
Are you an NSRA member?---They mail you a "Fellow Pages" book that lists guys that will help in all USA-----Just asking.---------Don
