Help needed please: 59 Olds 394 head gaskets
Discussion in 'The Hokey Ass Message Board' started by SGT Schlang, Jun 4, 2012.
  1. SGT Schlang
    SGT Schlang
    Hello hoping someone can help me need all I can get! :D
    I am ***embling a 59 394 and noticed that the new head gaskets (best gasket # 642 from full set for 59-60 394) are blocking off the following coolant p***ages. These were not blocked off by factory gasket and my machinst left all original coolant p***age plugs in the block.
    P***-Side: lower 1" coolant holes on deck (both holes between cyl # 6 and cyl # 8)
    Driver-Side: lower 1" coolant hole on deck (forward hole between cyl # 5 and cyl # 7)
    Don't want to install and create a problem. I've looked everywhere can't find if this is an improved gasket or if I have wrong gaskets!
    Thanks!!
    Sarge
  2. GOATROPER02
    GOATROPER02
    from OHIO
    Don't worry about the gasket.... Just make sure the deck plugs are in like the pic....
    And you'll be fine
    Tony
  3. SGT Schlang
    SGT Schlang
    thanks!! any idea where I can buy plugs?
  4. GOATROPER02
    GOATROPER02
    from OHIO
    I got any stock or speed part you could think of for your early Olds
    Tony
