Technical Help needed to identify this suicide front end please
Discussion in 'The Hokey Ass Message Board' started by V8 Kev, Mar 11, 2023.
  1. V8 Kev
    V8 Kev
    Hi All ,
    Got this suicide front end on my 33 chevy , Need new king pins , Its a aftermarket tube , Has grub screws to hold the king pins not cotter pins . Can anyone help me to identify the make or point me in the right direction of where to get the correct king pin set .
    Thanks in advance . kev
    210superair and chryslerfan55 like this.
  2. Happydaze
    Happydaze
    Does it really need kingpins, or just the bushings? The king pins shouldn't wear if the bushings are lubed and not allowed to completely wear out. The bushing will invariably be a standard engineering component, so you'd just need to measure up. Hone/ ream to final size when installed.
    Removal of the bushings isn't necessarily a destructive process so they could potentially be refitted after measurement pending replacement.
    Chris
  3. V8 Kev
    V8 Kev
    Hi Chris , Not taken it apart yet , But yeah i get what your saying , You got any idea where in the uk might have said Bushings ?
  4. Happydaze
    Happydaze
    Any bearing place. Try Simply Bearings online.
    Chris
  5. '29 Gizmo
    '29 Gizmo
    from UK
    Was it built in the UK? If so home manufactured tube axles used Transit and Anglia spindles. Both used grub screws.
  6. V8 Kev
    V8 Kev
    No , it was built in USA 2010 ish by a HAMB Member , I have asked Him , said he got from a swap meet in CA .
  7. V8 Kev
    V8 Kev
    Cheers Chris
  8. '29 Gizmo
    '29 Gizmo
    from UK
    Chevy maybe
    270ci and gimpyshotrods like this.
  9. Why is that a suicide front end?
  10. V8 Kev
    V8 Kev
    Gizmo , That does look like mine , I suppose when it was chromed it was polished to be smooth . So that screen shot is for what ? and from where please ?
  11. '29 Gizmo
    '29 Gizmo
    from UK
  12. V8 Kev
    V8 Kev
    It is mounted out front of Ch***is by a welded on bracket that them bolts to the transverse leaf spring .
  13. V8 Kev
    V8 Kev
    Thanks , Looks like it . Will look it up .
  14. Budget36
    Budget36
    I thought suicide front end had the tie rod in front? Didn’t know it was location of the axle.
  15. gimpyshotrods
    gimpyshotrods
    Tie rod in front is not a suicide setup, just a builder that doesn't understand physics or geometry.
    Axle not under the frame, which would catch it if the spring broke is a suicide setup.
    Tman, V8 Kev, Doublepumper and 2 others like this.
  16. 38Chevy454
    38Chevy454
    Spindle looks Chevy. 49-54 car is a quite popular spindle used for axles when a "Chevy" spindle is used.
    gimpyshotrods, V8 Kev and maneri like this.
  17. V8 Kev
    V8 Kev
    That was my understanding of a suicide , not under the ch***is , Thanks for your reply
    gimpyshotrods likes this.
  18. My first thought as well. Could be an old Speedway, CAE or PSE? Forget the acronym of the last one
