Technical help needed with 55 olds starter
Discussion in 'The Hokey Ass Message Board' started by buick61, Jun 26, 2021.
  1. buick61
    buick61
    have a 55 olds with a 324ci needing a starter motor , can not get it rebuilt as armature is beyond repairing .
    i can source a starter from a 59 olds with a 371 ci .
    does anyone have any experience with swapping these , are they interchangeable .
    thanks mike..
  2. 54-55 on the starter 56 will fit by changing solenoid if necessary
  3. one can get a armature from a 55-59 chev truck v8 also 54-56 REO 6cyl according to HOLLANDER
    302GMC likes this.
  4. vtwhead
    vtwhead
    Tony @GOATROPER02 offers a new smaller gear reduction starter if you wish to upgrade. Another option, just saying..
  5. buick61
    buick61
    yes , have that option , but would prefer an original style if i can make it fit ,
    thanks
  6. Paul
    Paul
    Editor
    The '59 starter will have a different bolt pattern than the '55
    If you want direct bolt in look for the '54-'56
  7. WB69
    WB69
    from Kansas
    Like you, I wanted to stay with the original. Eventually I switched to the gear reduction starter and have not regretted doing it one bit.
    triumph 1 likes this.
  8. Mr48chev
    With what Junkyarddog_1 posted you should be able to swap your end frame and solenoid onto a 55/59 Chevy truck starter just by switching end frames and maybe starter drives.
    I've swapped end frames on starters a lot to use the heavier duty fields and armature from another GM rig such as an Olds starter on a Chevy when I didn't have a heavy duty Chevy starter.
  9. I have about 20 new armatures, 40's and 50's, most are numbered and boxed, 3 are not. I will look for yours if you are interested. Dave
    Added: I have a lot of starter drives and brush sets also.
