Hi folks, need some help in what I need to make this work ? what I have is a 40 merc flatty in a 33 ford truck . the frame is one that was build with stamped rails& model a front cross member . the problem is fan clearance also the bottom pulley ,so we took of the pulley of the gen in hope to find a fan & pulley set up to place on the generater to mount the fan higher &run one belt. thanks
The stock 33-39 gen and fan should work fine. You can put a 56 case on a 39 gen and have a 12 volt gen with a fan mount. It would use one belt.
thanks andy I will see if I can find a 33-39 gen-fan as I already had my gen converted to 12 volt so I will just change the front that should work .
