Help!! Oil in the coolant
Discussion in 'The Hokey Ass Message Board' started by orca, Aug 23, 2012.
  1. orca
    orca
    from Sweden
    I have a Ford flathead -37 and i have oil in the coolant. What to dooooo??
  2. #1 Kawboy
    #1 Kawboy
    from Fl
    rebuild the motor most likely...cracked block....?
  3. orca
    orca
    from Sweden
    it's so bad?
  4. HOTRODPRIMER
    HOTRODPRIMER
    Cracked block or head gasket. HRP
  5. #1 Kawboy
    #1 Kawboy
    from Fl
    Ooops ! Read it wrong..thought it said coolant in oil..my bad sorry
  6. let me get this straight....you are getting the motor oil into the cooling system , and not coolant into the motor oil? i'm not sure how that could happen on a flathead
  7. orca
    orca
    from Sweden
    Thats right, not coolant into the motor oil!!
  8. cracked block or not...how is the oil getting into the cooling system? i can see a crack block or blown head gasket getting coolant into the oil
  9. bobss396
    bobss396
    From my experience, this is usually a 2-way street, usually the mix is in both the oil and water, amounts may vary though. As usual, a post with little information to go on.
    Bob
  10. Mike51Merc
    Mike51Merc
    Guys,
    Flatheads don't have oil p***ages in the heads, so a blown head gasket can't transfer engine oil to the coolant.
    The only way oil can get into the coolant is a crack "down under" in the valley of the valve train, and even then, I'd think the pressurized coolant would leak into the oil before the oil would leak into the cooling p***ages.
  11. bobss396
    bobss396
    Give me 20 seconds and I'll tell you all I know about flatties.
    Bob
  12. exactly ....that's why i don't understand what is causing his problem
    i see he is from Sweden so maybe something got lost in the translation
  13. orca
    orca
    from Sweden
    There is no cooling water/coolant in the oil but a lot of oil in the cooling water/coolant.
  14. Fenders
    Fenders
    Keep checking the oil -- add when low.
  15. hombres ruin
    hombres ruin
    Either way the engine needs to be pulled and looked at... But it doesn't look good for the old flatty
  16. flathead4d
    flathead4d
    Post your question on the fordbarn.com web site. Someone there will know the answer.
