Hot Rods help on 38 ford p.u. chop
Discussion in 'The Hokey Ass Message Board' started by frankieC, Feb 16, 2010.
  1. frankieC
    frankieC
    hey guys
    doing a 38 ford pu. its channeld 7in. cab mounts done firewall fabed in steering fabed floor braced need help on how lay out tape for a 4in. ore 5in chop???
    ANY BODY GOT PICS!!!!!
    THANKS FRANKIE C
  2. fab32
    fab32
    +1 for th rat rod crowd:(
    -1 for the traditional hot rod gang:mad:
    Frank
  3. 117harv
    117harv
    +1 for the new guys enthusiasm.
    -1 for an alliance member.
  4. AllSteel36
    AllSteel36
    Why would a chopped and channeled '38 Ford PU be a RatRod?
  5. oj
    oj
    I'm with 117harv. I believe this was a recent thread, same cab. Try doing a 'search', there were many replies complete with pics of how other guys did thier chops. It had a lot of detail on how to quater the roof and alternative methods. A very good thread. Try and search for 'pickup cab chop' or 'pickup chop' or something along those themes. Good luck, oj
  6. AllSteel36
    AllSteel36
  7. rustisgold
    rustisgold
    id did a 35 ford truck recently, used 2 roofs,i didnt want to lay back my A pillars so i cut my A pillars and front roof section down 1st, the used a the donor roof for the back section. this helped me in 2 ways-
    1st- leaving the donor rear roof longer to fill the gap (front to back) ment onlt 1 weld seam across the roof (side to side) wich means less weldein and less warpage
    2nd-my cab with minimal rust had a bad rear roof section, the donor roof off of a rust bucket cab was alot less bent up
    id olso recomend the 'how to chop tops' book, it may sound cheesey, but aeve after doing a few chops on different body styles it still proved to be quite a good read, many different chopping methods for mont different body styles
