help on head gasket sealer
Discussion in 'The Hokey Ass Message Board' started by V4F, Oct 26, 2013.
  1. V4F
    V4F
    from middle ca.
    does anyone have experience with a good head gasket sealer . I have an aluminum motor with a felpro head gasket . very small seep on front corner ................. thanks .. steve
  2. Engine man
    Engine man
    from Wisconsin
    The only one I've ever seen work is Zecol Mend***e.
    http://www.oreillyauto.com/site/c/brand.oap?mn=Zecol(R)&mc=ZEC
  3. primerhotrod
    primerhotrod
    from ILLINOIS
    Sounds like a surface issue.
  4. greg32
    greg32
    from Indiana
    If its a blue felpro, I put a light coat of silicone sealer around the water p***ages, on the gasket itself. No water leaks. Aluminum head and block tends to move around a bit with heat cycling.
  5. V4F
    V4F
    from middle ca.
    block & head just surfaced . new motor . thank you .. steve
  6. gatz
    gatz
    Have had real good results using Permatex's Hi-Tack Spray-A-Gasket adhesive, it's about the only thing that would keep a head gasket in an Oliver diesel.
  7. john walker
    john walker
    K&W spray coppercoat is good.
  8. Hotrodbuilderny
    Hotrodbuilderny
    Back in the day we used Aluminum spray paint, I don't know if Aluminum paint is still Aluminum pigment but back then it was.
  9. budd
    budd
    i have just spray painted a few old head gaskets and resused them with good luck, i let them dry over night till they are not tacky.
  10. Jack E/NJ
    Jack E/NJ
    from NJ
    steve>>>very small seep on front corner >>>
    Leave it alone. In time, it'll prolly seal on its own from aniti-freeze additives,
    Jack E/NJ
  11. Fogger
    Fogger
    I've been using Coppercoat since the '60s, even on the Felpro blue head gaskets. Never a leakage problem.
  12. Engine man
    Engine man
    from Wisconsin
    I ***ume he wants to seal it without taking it apart.
  13. brad chevy
    brad chevy
    Coppercoat has always worked for me on all engines.
  14. racer32
    racer32
  15. V4F
    V4F
    from middle ca.
    we used a fel pro + copper coat .
    yes we want to leave it on the motor .
    jack , your probably correct . .................... thanks all .. steve
