HELP!... overheating problems
Discussion in 'The Hokey Ass Message Board' started by TOADY, Jun 29, 2008.
  1. TOADY
    TOADY
    from london,uk
    Hi guys, hopefully someone can help me here, i have copied this that my friend has put on the NSRA site here in the U.K. to try and help me sort my problem out, ...........
    Hi all,
    I`m really struggling to get my head round this one, will try and explain
    again as I dont think this is a shroud issue,
    TOADS engine a 302 ho engine (1987) now the engine came complete with smog
    control, A/C, power steering pump all fitted to the engine all of which we
    junked, heres my problem (baring in mind this reverse water pump change
    over) the only pulley we have that fits the water pump is ribbed/toothed
    which tells me the belt runs as normal (not reversed) I did find an article
    that states that during the change over to reverse pump they did make a
    serpentine belted normal run water pump, TOAD did keep the old belts and it
    does look like the belt is shiney on the back of the belt so it would seem
    that it did run on the back of the belt which would suggest the reverse pump
    BUT! why do I have a pulley that is toothed/ribbed??
    this is not TOADS engine but basically how he got it
    And this is the pulley on the pump at the moment, you can just make out the
    grooves on the pulley if you enlarge the pic,
    PLEASE HELP! it is starting to do me nut in the words of Holmsey lol,
    very many thanks guys.......toady........(but thanks to cabby for trying to help me sort this issue out and for the engine transplant.
  2. Not sure of your question. You'll find that the grooved part of the belt will always run on the grooved part of the pulley. The slick part of the pulley rides the back side of the pulley. Hope that helps??
  3. JohnEvans
    JohnEvans
    from Phoenix AZ
    Who knows what someone may or may not have changed. If you need to run the grooved pulley obtain a new pump designed for normal rotation. You are going to end up pulling the pump on there now anyway to find out what it is.
  4. TOADY
    TOADY
    from london,uk
    Don`t know if this helps much? but its a 1987 ford 302 H.O. engine that had fuel injection system on but i have taken them off so i can run a 600 edelbrock carb but everything else is the same, so dont know if this helps anyone who can let me know if the waterpump runs in reverse rotation or not.............THANKS GUYS!......for any help given.............toady
  5. 1bdsinner
    1bdsinner
    from phoenix
    I am having high temp problems on the hiway. I have a 91 302 in my ford and when you look up the reverse waterpump it is completely different mount wise on the timing cover. Next i am goign to try a different radiator but i have new t stat,new waterpump and still running into issues... I need to get it keepin cool also cause summer is coming and az gets 110 for 4 months.
  6. Belt routing
  7. Francisco Plumbero
    Francisco Plumbero
    from il.
    Have either of you guys pulled and reinstalled the heads and put on new gaskets?
  8. this original post is from 2008.....you realize that right?
