help please! cannot send private messages
Discussion in 'Questions & Suggestions' started by Wallingford Noah, Oct 1, 2017.
  1. when I try to send private messages from HAMB app I get a message that says "not support module private mesaage" does anyone know what this means or how to fix? obviously cannot contact Ryan thru private message about this issue....
    thanks for your help.
    Sent from my SM-J700T using The H.A.M.B. mobile app
  2. Stu D Baker
    Stu D Baker
    from Illinois
    May need to do it on a desktop puter?
  3. HOTRODPRIMER
    HOTRODPRIMER
    The Hamb app doesn't work with all the features,follow Stu's advice and us a PC. HRP
  4. dammit just what I don't wanna do. I'll check it out. thanks
  5. could this also be why I cannot post parts for sale?
  6. gimpyshotrods
    gimpyshotrods
    I just sent you a PM from my phone. See if it goes through, and you can respond.
  7. nothing in my inbox... thanks for trying.
  8. gimpyshotrods
    gimpyshotrods
    Click on the three little dashes in the upper left hand corner of the phone app. Select settings. Scroll down to the bottom of that menu. That will show you what version number of the app you are running.
    Let me know what it is.
  9. gimpyshotrods
    gimpyshotrods
    Also, on your phone or tablet, find the little sprocket/gear market settings. Click on that. Scroll to the bottom. It will say "about phone" under which it will show you the version of the Android operating system that you are running.
    Post that too.
  10. gimpyshotrods
    gimpyshotrods
    For many:
    One thing to try, as long as you remember your p***word, is to clear the cache and local storage for the phone app. If you find Settings control panel, go the Apps section, find the HAMB app, click on it, you will find a list of settings. One of them is storage. If you click on storage, you should see "Clear Data" and "Clear Cache". Many problems can be fixed by clearing those two.
    If you have a stored p***word, this will clear it, so make sure you can remember it.
  11. El Jefe hemi
    El Jefe hemi
    from BC Canada
    Noah, I see you have been having troubles with messages. I sent you a couple pm’s yesterday, not sure if you received them?
  12. wbrw32
    wbrw32
    Noah,,GET OFF THE PHONE AND USE A COMPUTER.............problem solved.
    ManChu likes this.
  13. Flathead Dave
    Flathead Dave
    from So. Cal.
    Are you logged in to the HAMB on your phone?
  14. HOTRODPRIMER
    HOTRODPRIMER
    The Hamb app doen't work for posting ad's. HRP
