help please, infor on quarterpanel 49-52 chevy
Discussion in 'The Hokey Ass Message Board' started by jetslide, Oct 11, 2012.
  1. jetslide
    jetslide
    from norway
    does anybody know how big of a diffirence it`s between 49-50 chevy 2door quarterpanel and 51-52 quarterpanels, is it possible to make the 51-52 by cutting to fit on a 49-50`s car without alot of work and metalshaping
  2. 49ratfink
    49ratfink
    if you are swapping a complete factory quarter panel from a 51 onto a 49 it should swap right over with minimal extra work compared to putting a 49 panel on a 49.
    one thing to note, you will need to use the 51 tail panel that goes between the bumper and the body from the 51 as well. the contours of the body are different in the rear.
  3. jetslide
    jetslide
    from norway
    i see, i`m trying to find a new panel for my 49 and the only thing i have found so far is a 4 door 52 here in norway that i can cut from, so the plan was to shape it into a 49 panel if thats possible
  4. The entire back half of the 49-50 quarters are different than 51-52 quarters. Do a search online and see the slope of the back half is much less than the 49-50 because the 51-52s had the tailights in the tip of the quarters....40-50s did not. If all you need is the front half or just the bottom portion, you may be able to cut/splice into your old quarters depending on how good you are at metal work.
    All that said.....I thought it might look cool to install 51-52 quarters [with their extended rear 1/2] on a 49-50 sedan delivery.
  5. RustyJim
    RustyJim
    from Indiana
    You can buy patch panels fo the bottom half here in the states could you repair what you have?
  6. terryble
    terryble
    from canada
    I can tell you from experience the quarters are very different from about the center of the wheel well back. Where it connects to the rear panel is completely different and the lower portion is longer and again completely different in shape. Depending on how much of the panel you need it may be possible to piece together.
  7. 49ratfink
    49ratfink
    anything is possible. show a picture of what you are trying to repair.
  8. jetslide
    jetslide
    from norway
    i have bought the lower patch panels but the shap of the top half on the fender is way off so i was hoping to maybe cut to fit an 51-52 quarter if that was possible than making a new one on the english wheel
    as you can see the panel is welded and knocked way out of shape
  9. 49ratfink
    49ratfink
    looks like that car has already had a partial quarter welded on half assed.
    you need more than a 51 4 door quarter could provide.
  10. jetslide
    jetslide
    from norway
    thank you for the comforting words ratfink:D
    well i`ll get it right somehow, was just hoping for a short cut
  11. 49ratfink
    49ratfink
    I just post the facts, comfort will have to come from someone else.:D
  12. jetslide
    jetslide
    from norway
    ha ha ha ha, just told the wife what you wrote and she just shaked her head:)
  13. riskybiz
    riskybiz
    Jetslide, I might be able to help you with finding another 1/4 panel for your 50 Chevy. I have boughten alot sheet metal parts over the years from a wrecking yard in Fresno California named
    Turner's Autowreckers
    559-237-0918
    They have over 50 acres of cars. I bought a roof for my 54 Ford from them. So I think they would have a 1/4 for you. Now getting it shipped to Norway????. But it is a place to look at.
    Hope this info can help you out.
    I have a 50 Chevy Fleetline
    Charles....
