HELP PLEASE: need to find a part
Discussion in 'The Hokey Ass Message Board' started by misfit36, Mar 25, 2008.
  1. misfit36
    misfit36
    from new york
    well just as i started making headway on my brakes, i took a step back. the part i need is the " u " shaped bracket that threads onto each of the rear emergency brake cables, and the parking brake cable that goes to the handle in the cab. these brackets all hold the cables on the center parking brake bracket under the rear crossmember. i also need the pins that go through it with the cotter pin hole. pic is below. no one ive tried has this part including napa, joblot, and a local truck parts store. ive looked on macs, midfifty, and vintageford. oh its for a 52 F1.thanks
  2. slddnmatt
    slddnmatt
    hardware stores will usually have them..
  3. misfit36
    misfit36
    from new york
    slddnmatt, you know i didnt even think of that. im new to this so i figured they were only made for this application. i gotta start thinking outside the damn box. thanks for the quick reply.
  4. Russco
    Russco
    from Central IL
    would something like this work they are common Gokart/minibike parts check ebay ebay under clevis or brake parts
  5. 460 willy
    460 willy
    from wisconsin
    Check with a farm supply store they have all sorts of stuff like that just think outside of the box and you will find one
  6. Tractor supply, Grainger, McMaster Carr.......
    Have you found them yet?
    One particular use is to triangulate/support a door or gate so it wont sag.
    Maybe look near the allthread.
    Try a search for turnbuckle, this is a related part and may show up as well.
    You might also look here:
    http://www.aircraftspruce.com/
  7. misfit36
    misfit36
    from new york
    got em', i ordered them from this place Green Sales. someone on fordtrucks.com gave me the link, they have all sorts of oddball fordparts.
  8. misfit36
    misfit36
    from new york
    these are the part numbers if anyone was interested.
    1948/52 F1 / 1948/51 F2-F3
    73963-S7 .. Clevis Pin ~ 5/16" x 1 1/2"
    357337-S .. Clevis ~ 5/16" -24 x 2 1/4"
  9. misfit36
    misfit36
    from new york
    sorry, i forgot to thank everyone for the help.
