help please (radiator)
Discussion in 'The Hokey Ass Message Board' started by alley cat 1, Aug 8, 2006.
  1. alley cat 1
    alley cat 1
    so im back for more help, thanks in advance! the story goes like this.. i keep blowing radiator hoses off. 1. checked thermastat ... stuck and removed.
    2. my hoses are those flex hoses with 3 inch rubber at the tips (i know these suck and will be removed as soon possible)
    so if i have no thermastat and the water is running freely why do i keep poppin hoses off. i just ran the car up to about 120 degrees(which is not really all that hot) and it popped.!!!!
    question why is it building up so much pressure????
    thanks
    larry
  2. Pooch
    Pooch
    from Oklahoma
    what kind of car ? How are you connecting the hoses to the rad or engine? What moter?
  3. alley cat 1
    alley cat 1
    51 chevy
    350 73 vette motor
    standard hose clamps
  4. Pooch
    Pooch
    from Oklahoma
    What radiator? Where is it poping loose?
  5. Skirv
    Skirv
    I am not sure about the radiator hoses. what type/size of clamps? are they blowing at the radiator or the engine? Are the ends of what you are connecting the hoses to expanded so that when the hose is tightened, it can't slip off?
    FYI - If you don't use a thermostat, you should use a restrictor in it's place. The coolant system was designed to have some restriction there to keep the coolant from flowing too fast through the system. Lack of said restrictor can cause overheating.
  6. HemiRambler
    HemiRambler
    If your sections the rubber hose slips over do not have a "hump" or protrusion then I say expect to continue this trend. IF they do then it suggests you have LOTS of pressure - faulty radiator cap. They make a radiator/cap checker - maybe ask around and see if a buddy has one you can borrow.
  7. TRUCK_RAT
    TRUCK_RAT
    from tulsa
    here's a slippery slope of a question for you.
    is it possible or plausible for a headgasket leak to be pushing compression into the coolant? probably not but the glass is half empty and anything's possible
    my guess would be something clogging the system like perhaps a rag stuffed in somewhere to hold out dirt and then accidentally forgotten.
    i've heard that if you mix red and green antifreeze it turns to some sort of foamy goop that can clog your radiator and engine. but i haven't "seen" proof (and i'm not trying it in my car)
    have you tried to change your radiator cap?
    i guess something is plugged up
  8. Skirv
    Skirv
    Okay, I see the pic. Are they slipping off of the coolflex or the thermostat housing/radiator, and do those rubber connectors have smaller adaptor rings inside them?
  9. alley cat 1
    alley cat 1
    sorry dont the name of the rad..its a alluminum with a fan on the inside, cant rember nameDUH!!!!!
    and she will pop a hose anywhere and anyone shes not picky
  10. alley cat 1
    alley cat 1
    clamps and everything should be good?!!?? i am having them replaced just cant get there .... and the thermastat removal is just a temp situation to get a little further down the road.
  11. alley cat 1
    alley cat 1
    cool, never checked to see if a hump is there or not. when i replace these hoses they will for sure
  12. alley cat 1
    alley cat 1
    good thoughts. it would be my style to leave a rag in a plugged up hole!! good thing im not a surgen. i will check the cap
  13. Pooch
    Pooch
    from Oklahoma
    The rad cap should blow off pressure before the hoses come off. Do you have a recovery tank or is it a total loss system? Do you know th pressure on the cap ususually its around 13-16 lbs. If you know anyone with a rad tester they can pressure test your cap or just pick up another one they are cheap. Then check the over flow tube fo restrictions.
  14. alley cat 1
    alley cat 1
    the thermastat and the other connections. they never come off the flex tube. no to the adaptor rings.
  15. alley cat 1
    alley cat 1
    im gonna give the big WTF!?!? im as green as broccoli when it comes to this.
    recovery tank??????
    pressure????
    over flow tube ?? which one is that??
  16. alley cat 1
    alley cat 1
    it seems as if i should start with new hoses and a new cap.. i will take it from there and see what happens. you may here from me again. hopefully not on this issue
    BIG thanks to all you guys who throw me support while i learn my way around this car. THANKS AGAIN you guys rock
    larry
  17. Pooch
    Pooch
    from Oklahoma
    Sorry I didnt mean to go over your head. On the radiator where the cap goes on there is a tube sticking out the side under the edge of the cap. Does this have a hose on it and does it leak water before the hoses pop? If you have this plugged it will not allow the radiator to equalize pressure.
  18. Skirv
    Skirv
    By overflow tube he means you should have a small tube exiting the filler neck just under the radiator cap. That tube can just exit toward the ground (total loss) or into an overflow or recovery tank.
  19. Kustomz
    Kustomz
    I had a similar problem on the water pump caused by new paint making the surface too slick. When the cooling system pressured up off came the lower hose. Roughed up the area and no luck and it even had the hump on the end of the outlet to help hold it. Everything in the cooling system and on the engine checked ok so I put double clamps on the hose and solved the problem.
  20. alley cat 1
    alley cat 1
    it has a hose and a tank that it goes to this is it...but then it runs to the engine withano[​IMG]ther thermastat gauge on it, i will post pic
  21. alley cat 1
    alley cat 1
    heres [​IMG]the gauge dealy-o
  22. Pooch
    Pooch
    from Oklahoma
    Your pic is too small to see properly but I trhink we may have found the problem
  23. alley cat 1
    alley cat 1
    dont leave me hangin!!!!!!! welll?????????
  24. Pooch
    Pooch
    from Oklahoma
    I am having AOL issues sorry. Take the hose under the cap off and try to blow through it. I cant see a vent in the over flow tank, could just be the pic.
  25. Skirv
    Skirv
    Can you post a bigger pic of where that overflow line goes to on the engine. That's not right. That shouldn't be going to the engine.
  26. alley cat 1
    alley cat 1
    well like i said im GREEN that hose is not going to the engine!!!!!! dont know wht i was thinking, a little jumpy on the deal sorry for wasting your time on that part.
    larry
  27. alley cat 1
    alley cat 1
    i just took the hose off and there is no obstruction. but as far as a vent?? dont see one. it hooks straight to the rad to the tank.
    where doses that water go? is there a drain under the tank??
  28. alley cat 1
    alley cat 1
    cant rember if i said this or not. but at the head where the thermastat is housed im having problems getting a good seal there. could that be building up the presure? and it always blows off the engine side now that i think about it.
  29. Pooch
    Pooch
    from Oklahoma
    You can blow through the tank? take the cap off and check the rad tube for a problem I have seen them pluged with slag from brazing them on.
  30. alley cat 1
    alley cat 1
    if i pour water into the tank should it drain on the bottom???
