1952-59 Ford HELP !!! Problems With My Offy Intake/Clifford Header Install
Discussion in 'Off Topic Hot Rods & Customs' started by trikepapa, Sep 14, 2012.
  1. trikepapa
    trikepapa
    This install is giving me fits!! I’m installing an Offy intake with 2 1904 Holley's along with Clifford shorty headers on my 54 Customline, 223. I rebuilt the carbs and worked through clearance issues because the Offy intake is built to mate up with the stock type exhaust manifold heat riser ports. Since the Clifford headers aren't built to connect to the intake, I just hooked them up with the heat riser ports on the intake left open because I thought the bottom cavity is separated from both exhaust and intake flow. Am I incorrect? When I fired the engine up, it was running full throttle even though the linkage was set in idle position. Are the carbs ****ing huge quan***ies of fuel because of the open heat riser cavity? Any help will be greatly appreciated.
    Trikepapa - RonC
  2. JeffB2
    JeffB2
    from Phoenix,AZ
    You might find the best info to help you here contact these guys: http://www.exeterautosupply.com/ Let us know how you make out. Exeter is a long time Offy dealer and is also a HAMB Alliance member,you may also want to post on www.fordsix.com
