I'm trying to remove the p***enger door and quarter gl*** on my 1955 2 dr post mainline. I got the quarter window out - but not sure how. I'm afraid I'll really scratch it up putting it back in. Anyone can walk me through the proper way to remove and install these?? Thanks!
I found info on the door gl*** - it's out no problems. Both are at the gl*** shop now being copied. I only need info how the quarter gl*** is installed. Thanks!!!
By quarter gl*** you mean the vent window? if so install it first,you should spray the front door gl*** run with silicone spray before putting in your door gl***,also put a fair amount of white grease on the rollers inside and out and along the window track they roll on.
