Hot Rods HELP required
Discussion in 'The Hokey Ass Message Board' started by TinIndian1965, May 29, 2024.
  1. TinIndian1965
    TinIndian1965
    I recently imported a ‘46 Ford Super Deluxe into the UK. Want to change all the brake parts. Mater cylinder and rear wheel cylinders no issue.
    My stumbling block are the front wheel cylinders, as they have been updated, but can’t seem to find any vehicle references from what they came off of. They are stamped Wagner FD-18292 and Wagner FD-18293, I’m now stuck as one side seized and the other is weeping. Piston bore 1 1/8, mounting bore 1 11/16.
    Could anyone please shed some light. [​IMG]
  2. F-ONE
    F-ONE
    from Alabama
    I found the fd-18292 after a quick internet search.
    There are several with photos and specs.
    Prices range from 25-95 dollars depending on vendor.
  3. j hansen
    j hansen
  4. egads
    egads
    Dont know what there off of but the kit # is Wagner f 13620. That casting # has several different configurations, such as 7/16 24, 3/8 24, 7/16 20 inlets.
    TinIndian1965 likes this.
  5. TinIndian1965
    TinIndian1965
    Cheers Buddy. Yeah I’ve found them on line, but no one specs which vehicle they are from.
  6. Doublepumper
    Doublepumper
    from OR-WA, USA
  7. Oneball
    Oneball
    RockAuto is good for cross reference, you can put a part number in then click on what it comes up with and it’ll give you a fitment list, based on the above link I put in 1793118 and got:
  8. TinIndian1965
    TinIndian1965
  9. TinIndian1965
    TinIndian1965
  10. alchemy
    alchemy
    How about you post a picture of the backing plate and we tell you what the brakes are from?
    Moriarity and TinIndian1965 like this.
  11. TinIndian1965
    TinIndian1965
    Brilliant looks like they are off a 1959-1964 F-250. Thank you.
    Oneball likes this.
  12. alchemy
    alchemy
    You probably have repro Lincoln brakes on the front. Pretty sure the cylinders in those were common for decades.
    seb fontana likes this.
  13. What are the other numbers?
  14. Last edited: May 29, 2024
  15. Mr48chev
    This is going to call for posting some good quality photos of the brakes Backing plates and drums. Both sides of the backing plate. This so somone might recognize what changes were made.
  16. seb fontana
    seb fontana
    from ct
    I am thinking F1 brakes
  17. TinIndian1965
    TinIndian1965
    There are no other cast numbers. All that’s on the unit is Wagner FD-18292 and Wagner 18293 no other numbers.
