HELP: Small, good-looking ALTERNATORS???
Discussion in 'The Hokey Ass Message Board' started by KIRK!, Feb 15, 2007.
  1. KIRK!
    KIRK!
    This has to have been asked 100 times already, but I didn't find any with "search."
    So, any suggestions for decent looking and small (but capable) alternators. One wire setup prefered.
    Photos?
    NEW question: What is the minumum reasonable output? Is 35 amp enough?
    Thanks!
  2. Abomination
    Abomination
    What about the newer ones that are 50s & 60s Mopar look-alikes (except they're smaller and put out more juice)? I believe they're Toyota or Mitsubishi - and they're cheap, too.
    I wish I remembered more, but I can tell you I found the info while doing a search for something that lead me to a few articles on people going this route to avoid the infamous "low charge at idle" that happens sometimes.
    ~Jason
  3. DIRTYT
    DIRTYT
    from Warren,MI
    1990 corvette is just like the normal GM units but smaller and its 100 amp
  4. bwiencek
    bwiencek
    Racemate is one that fits under a water pump pulley on a small block chev (and probably other) - it's stealth since nobody will know it's there unless they look hard. I believe they're only 60 amps max if I remember.
    Other than that - the small import alternators are a good choice for under 100A loads, over that, well you're looking at large truck or loaded up cars. One wires aren't all they're cracked up to be - yeah they're a little cleaner, but not that it's a big deal - You can convert a Delco 10Si or 12SI to run one-wire with kits, or you can wire them up and only use a charge wire if you've got a battery cutoff switch.
  5. john56h
    john56h
  6. langy
    langy
    Toyota, Mitsubishi, Diahatsu most of the Jap cars have them.
    Not sure if you have Kubota in the U.S. but the engines have tiny alternators.
    Steve.
  7. vintage56
    vintage56
    I know we have kubota tractors... same???
  8. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    I'm using a Toyota smallternator on the '50 Burb...... polished up nice, from a '90 Tercel or something. 3 wire hookup, charges nice.
  9. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    Sorry, no pic... they all came back as too large. I'll try to add one when I get home.
  10. KIRK!
    KIRK!
  11. blown49
    blown49
    1992 or 3 Pontiac Sunbird....90 amps I think.[​IMG]
  12. j ripper
    j ripper
    from napa ca.
    first a heater for your modified. now this. yer killin me...
  13. ibcalaveras
    ibcalaveras
    Kirk,
    Contact Stephen our Dad has a source for small one wire alternators in Gilroy. $100.00 I thought...
    I'm planning to get one from this guy for my T bucket, I need something smaller than the Delco SE. I think that it is off a chevy Corsica, they will know for sure... Donn
  14. SimonSez
    SimonSez
    Here's an old thread of mine with pics of a small Nippondenso alt ...
    http://www.jalopyjournal.com/forum/showthread.php?t=75168
    They look similar to the smaller ones on the Jones Racing site.
  15. KIRK!
    KIRK!
    Totally ****ing GAY! Next week I'm asking about enclosed trailers.
  16. mustangsix
    mustangsix
    Motorcycles have small alternators that could be put into a homemade custom case.
  17. I talked to a guy selling some nice little mini alternators at a swap meet. The larger of the two were older Toyota Camry ones that he had rebuilt and modified to work as a one-wire. The really tiny ones weren't one-wire, but they came out of older Suzuki Samurais. They both have v-groove pulleys, but the pulleys seemed to me to be slightly narrower than the v-grooves on American cars. He said they work fine though with normal fan belts.
  18. pan-dragger
    pan-dragger
    anyone ever used the racemate?
  19. I recall an articel in Street Rodder (easy now...) about a firm that was modifying small alternators to fit in the cases of generators. Very slick and looked like a generator. If I remember right the ouput was inthe 35-50 amp range but it's been awhile since I read that article.
    Of course I don't remember the year or month.... sorry.
  20. KIRK!
    KIRK!
    OK, I just ordered one from these guys - http://www.ecae.com/alt-kits.html
    I got the 2025 mini alternator. It puts out 45amps, which is more than I need after talking to the guy. They were very helpful. They have some pretty clean looking kits for SBC, but didn't have any for my 194. Not a problem - I'm fabricating 90% of the car anyway - what's another bracket?
