Help solve an electrical problem
Discussion in 'The Hokey Ass Message Board' started by Zombie 51, Jun 9, 2009.
  1. Zombie 51
    Zombie 51
    from New York
    My buddy has a '50 Olds with an electronic trunk release. Its a button mounted in the ashtray that activates a solenoid and trunk popper. You know...standard stuff. When he gets on the highway and gets up to speed... POP! The trunk opens. Any ideas how to run down the problem without me riding in the trunk on the highway with a tester??? Lol
  2. Bruce Lancaster
    Bruce Lancaster
    First, try removing the power wire from the switch and taking a ride. My immediate thought is that mebbe it is not an electrical problem but a weak latch popped open by an aerodynamic issue at X miles per hour..
  3. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    Or a shitty switch that closes when bumped.
  4. Dan10
    Dan10
    from Joplin
    I second unhooking the switch and trying it. If that stops it, replace the switch. If it happens with a new switch, I would suspect a shorted wire.
  5. Gnashty1
    Gnashty1
    I'm with Bruce on this one, especially if it is repeatable. I do think the "ride in the trunk" thing might be a good entry for tech week.:)
  6. chopolds
    chopolds
    from howell, nj
    1. Kustom Painters
    Check the mechanical aspect of it, too!
    If the cable, or rod that goes to the latch doesn't let the latch completely return to it's "neutral" state, it will latch, but pop open when you hit a bump. My 55 Olds did that for the longest time, until I found it!
  7. glenn33
    glenn33
    from Browns, IL
    I think Bruce is on to something here...
  8. Zombie 51
    Zombie 51
    from New York
    Thanks guys. I passed on your suggestions. I'll let you know how it works out
  9. Gnashty1
    Gnashty1
    Zombie -
    How did this turn out? Electrical? Mechanical? Weak latch?
  10. d2_willys
    d2_willys
    from Kansas
    Hey, wait a minute, that ride in the trunk thing might be ok. That is a big trunk and there is a trunk light to keep you out of the dark. Jusk kidding, go with Bruce's idea.
