Help :: starliner Down :: may cause dangerious
Discussion in 'The Hokey Ass Message Board' started by Gambino_Kustoms, May 22, 2008.
  1. Gambino_Kustoms
    Gambino_Kustoms
    Alliance Vendor
    heres the delema we need a tow rig to take kirks car to santa maria its some thing we HATE to do ,were have a timing issue , theres no power we tried every thing to get this car going along with about 30 athere people who are with kirk right now !!!it almost seems like the timing chain maybe jumped its the only logical answer it would realy suck if this car did not make it to paso maria
    HELP HELP HELP
    408 561 5744
  2. junkcad
    junkcad
    from nashville
  3. Abomination
    Abomination
    Bump for Kirk!
    ~Jason
  4. KIRK!
    KIRK!
    I'll keep my fingers crossed.
  5. phlip
    phlip
    maybe try the condenser, they can cause all kinds of problems that make you chase your tail.
  6. Pull the T/C and check it. Highly doughtfull it jumped timing. Maybe the balancer slipped
  7. 54BOMB
    54BOMB
    Check if the plate in the distributor that holds the points is wiggling around, my old galaxie did that right after I bought. Acted really wierd, stalling, loss of power then normal and then back and forth. Had to switch out the distributor.
  8. kustombuilder
    kustombuilder
    from Novi, MI
  9. stude_trucks
    stude_trucks
    This is when when we need the Rocky music - good luck!. I want to see that car there:
    <object width="425" height="355"><param name="movie" value="http://www.youtube.com/v/bMK_SuKjOKk&hl=en"></param><param name="wmode" value="transparent"></param><embed src="http://www.youtube.com/v/bMK_SuKjOKk&hl=en" type="application/x-shockwave-flash" wmode="transparent" width="425" height="355"></embed></object>
  10. Ryan
    Ryan
    ADMINISTRATOR
    Someone has to have a trailer.
  11. Bigdaddy
    Bigdaddy
    I have AAA Premier..... 200 miles tow and 3 100 mile tows.... all mine are used up till the end of the month or I would give you one...
  12. Bigdaddy
    Bigdaddy
    Ya, Uhaul.....
  13. can you tell us some more symptoms??? maybe we can get this bitch going. i had a 302 skip a timing tooth one time & it wouldn't even run. might be something you guys are overlooking, or maybe its just an excuse for kirk to trailer his car without getting ribbed to hard for it! hahaha
  14. 61TBird
    61TBird
    Hey Alex! Notch just called me and told me.
    My Truck (the Tiki Bar special) should be out of the body shop tomorrow.
    He has my number and he'll pass it on to you.
    You know I'm there if you need help.
  15. Also, make sure the vacume advance is working. If not, no power.
  16. Haunyawk
    Haunyawk
    I got a Duramax but no trailer and I'm leaving Sat. A.M. If I can help let me know. I was gonna take one of the more fuel friendly rigs, but If You need me to tow it, I'll do it.
  17. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    Pull the cap off the distributor. Put a breaker bar / socket on the crank snout bolt. Turn right until rotor starts to move. Note where rotor is. Mark balancer at timing tab. Back crank bolt until rotor starts to move other way. Mark balancer at timing tab. That'll tell if you have sloppy timing chain.
  18. SLAMIT
    SLAMIT
    Alex. Check and see if the points plate in the distributor is loose like someone earlier had said. Also check and make sure that the points are actually adjusted correct and make sure that they are very tight. I had a set keep coming loose on me when I had my galaxie and it would lose power then eventually not start. or just run like asshole. Does it have an Electronic Ign????
    If you want to call me and maybee talk about the symptoms i can try to help. I do this shit for a living so maybee i can be of some help. I am in San Jose at work. but have to go home to Santa Cruz tonight.
    Eric
    831-535-2206
  19. Gambino_Kustoms
    Gambino_Kustoms
    Alliance Vendor
    it has a petronx in it
  20. I swear by Pertronix but this week I was Swearing at it. I installed a New unit and it was put together Wrong. It created a Rotor Phase problem that nothing could fix. I changed the complete dist to one I knew worked and problem went away. It acted like crossed plug wires and really had me chasing my Tail. Even checked to see If I had wiped out a Camshaft. It was the Pertronix all along. Something to check out for sure.
    The Wizzard
  21. Nads
    Nads
    from Hypocrisy
    I had a Pertronix fail on me on my way to Miami, it happens.
    Good luck.
  22. notebooms
    notebooms
    Alliance Member
    Alex-- call anissa and have her check to see if i've got a low tow still left on my premier AAA account. if so, you guys can use it...
    im in london, by the way-- and i hate not being there for santa maria....
    -scott noteboom
  23. Has this motor ever ran with this dist in it?
  24. Gambino_Kustoms
    Gambino_Kustoms
    Alliance Vendor
    waiting on the car right now
  25. Gambino_Kustoms
    Gambino_Kustoms
    Alliance Vendor
    yes thats what funny
  26. those pertronix are kinda sensitive to coils too, if you dont run the matching coil it could affect the performance, or fry the pertronix too. put some points in it just to see if thats the problem or not. wouldnt take that long.
  27. A compression test or a Vaccumm gauge will tell if the Timing Chain slipped. You should also be able to take the Fuel pump off the Ford motor and get your finger to the Chain. Lots easier than tearing it all apart for nothing.
    The Wizzard
  28. stude_trucks
    stude_trucks
    put the old distributor back in?
  29. Does it crank, and if so, do the rocker arms move? Can you see without taking the valve cover off? I'm betting it's an ignition/coil issue.
  30. DE SOTO
    DE SOTO
    HAS THIS CAR BEEN SITTING FOR AWHILE & NOT STARTED ???
    This may sound funny & a bit stupid.... But its for real !!
    Happens on my Flatbed about every 3 mos & when we bought my daughters '55 Ford from a guy who didnt drive it much... We drove it and it ran O.K. it had real low power.
    CHECK THE RUBBER FUEL LINE BEFORE THE FUEL PUMP & AT THE TANK !!!
    The new gas has so much weird shit in it the rubber will dry up & split causing an AIR leak upon suction.. Wont leak Fuel, but WILL suck AIR !
    Worth a shot & you would feel like shit if the car didnt go cus of somthing so simple
