Help! Starter dead... rookie question
Discussion in 'The Hokey Ass Message Board' started by DJR13, Aug 27, 2008.
  1. DJR13
    DJR13
    from Venice, Ca
    53 Chevy 235 w/12 volt battery - slow crank for last few days. Dead today. Battery still charged (amp meter jumps, radio & headlights work). So I ***ume it's the starter. I have very little experience with working on cars.
    It looks as though Napa sells the Starter separate from Solenoid. Do I need to replace both or just replace the motor and use solenoid that's on it?
    Any help is much appreciated. Of course I'm registered for Primer Nationals this weekend. Good timing!
  2. Petejoe
    Petejoe
    from Zoar, Ohio
    Remove the battery and have it checked at a parts house.
    If good..
    Reinstall, start engine at high idle, get a voltmeter (time to buy one) and run leads to each positive and negative post on the battery. Be sure the volt meter is set on a low voltage reading. Some have a switch for this. You should be reading at high idle around 13-13.5 volts.
    If you are reading 13.5 volts its time to replace and check all your leads and grounds to the engine, starter, body and frame. If you are positive they are in perfect shape...
    Have your starter checked out and Replace the starter motor if needed.
    If you are not reading at 13.5 volts with the voltmeter get back to us.....
  3. DJR13
    DJR13
    from Venice, Ca
    COuld I just give a jump start and see if this works? This should tell me if it's the battery or not, right?
  4. Petejoe
    Petejoe
    from Zoar, Ohio
    Speaking of cables..
    the car should be equipped with ("00" size) battery/starter/ground and starter solenoid cables. You should have grounds from the frame to the engine/ from the frame to the body/ from the engine to the body. Clean all the surfaces these are connecting use dielectric grease on them before attaching.
  5. Petejoe
    Petejoe
    from Zoar, Ohio
    jump starting may get you from point A to B. But it is not the way to diagnose.
    Nothing more embarr***ing than having a car not start at the Primer Nationals
    due to problems you had (before) you left .
    Checking a battery at a parts store is free! Save your money on the voltmeter you will need while your there.
  6. DJR13
    DJR13
    from Venice, Ca
    Ha! Good point. Thanks for the help.
