HELP: starter motor keeps cranking
Discussion in 'The Hokey Ass Message Board' started by BlackFlag, Jul 9, 2005.
  1. BlackFlag
    BlackFlag
    I just got my car to fire up after some work, and when it did the starter motor kept on cranking. Im thinking that its a problem with the starter relay, but Im not completely sure so if you have any other ideas, please let me know.
    Heres the vehicle incase you need it.
    1959 galaxie
    352 engine
    Cruise-o-matic
  2. BlackFlag
    BlackFlag
    ANybody? Porfavor senores?
  3. gtnrkix
    gtnrkix
    Hey, I agree with yiou, it's most likely the starter solenoid that sticks. To eliminate the ignition circuit, unplug the S wire at the sloenoid and touch a hot wire to the solenoid to crank it. Good luck. AL
  4. noboD
    noboD
    BTT. Do you mean the starter runs after the engine is running? Sounds like selenoid{sp} is sticking or starter is shimmed too close to block and gear is sticking in flywheel. Ford experts??
  5. RoadKat
    RoadKat
    With a partially discharged battery aand a relay that is arc burnt, the relay can stay engaged because it is partially welded in place. I have seen that happen a lot with cars that are hard to start[ long cranking times] Replace the relay first and make sure the batt is fully charged.
  6. BlackFlag
    BlackFlag
    thanks guys, looks like im gonna go out and get a new one. I dont think its the starter being too close because i havent adjusted that and it ran before i did the work.
  7. Sean i had the same problem, but i even replaced the relay check for shorts on the + battery cable and double check the 3 or 4 wires that run to the ignition switch.
  8. Machinos
    Machinos
    Did you mess with the ignition switch at all? When I replaced that on my RV I got some wires mixed up, and it'd crank all the time when it was running.
  9. BlackFlag
    BlackFlag
    No, I think what happened is that my positive battery cable shorted and it essentially welded the switch open. Ive replaced the battery cables since then, so now all thats left is getting a new switch.
  10. Flat Ernie
    Flat Ernie
    Tech Editor
    It is almost definitely the starter relay. Be sure your cables are in good condition & battery charged. Don't crank it for very long if it doesn't want to start either.
  11. LOST ANGEL
    LOST ANGEL
    RoadKat got it. That is the most common cause for a starter to stay engaged.-MIKE;)
