Hot Rods Help , suggestions , improving ride 40 Ford coupe
Discussion in 'The Hokey Ass Message Board' started by putz, May 7, 2024.
  1. putz
    putz
    from wisc.
    trying to improve ride on 40 ford coupe , shocks ? Mustang 2 front suspension , ch***is eng, rear ... looking to have a smoother ride .... any suggestions appreciated , Jack
  2. Moriarity
    Moriarity
    SUPER MODERATOR
    Mustang 2 Pinto IFS is off topic here
    warbird1 and guthriesmith like this.
  3. Petejoe
    Petejoe
    from Zoar, Ohio
    I’d suggest re-arching your springs and new shocks. The original suspensions on those are very smooth and easy to steer.
  4. putz
    putz
    from wisc.
    shocks are new and springs ... type of shocks ??
  5. FrozenMerc
    FrozenMerc
    What is the car doing now that you don't like? Bump Steer? Harsh Ride? Too Stiff? Too Soft? Wallowing? Something else?
    Generic questions get generic answers from the internet. Please add specifics.
    I am sure whatever the problem is, it can be cured with spring and dampener changes. I have 20 years of suspension testing and engineering experience on everything from ATV's to 85,000+ lb Fire Trucks, and there are plenty of other suspension gurus on here as well, but we need to know what you are dealing with, and what you want corrected to get started.
    warbird1, Mr48chev, TerrytheK and 3 others like this.
  6. Tim
    Tim
    from KCMO
    Yeah what’s it doing? A set of better shocks and new bushings threw out can do wonders
  7. putz
    putz
    from wisc.
    ride is stiff , every thing new , BFG tires ....
  8. sidevalve8ba
    sidevalve8ba
    How much air are you running in those BFG's?
    TerrytheK and Tim like this.
  9. Moriarity
    Moriarity
    SUPER MODERATOR
    My 40 rides beautifully on BFGoodrich bias plies with 24 psi
    guthriesmith likes this.
  10. TerrytheK
    TerrytheK
    As mentioned, there are lots of things that contribute to ride quality. Tire pressure as mentioned is an easy first step. One thing not mentioned is whether those BFG tires you're running are low profile? Both my '39 Fords had dropped I-beam transverse leaf spring front and parallel-leaf rear suspension. When I ran smaller wheels and tires up front they seemed to amplify every tar strip and pebble in the road. Running taller tires I had no complaints about the ride at all.
    But part of the issue may be that "ride quality" is somewhat subjective. I like a firm ride - you may not.
    Good luck sorting it out.
  11. Mr48chev
    On any leaf spring rig that hasn't had the springs either replaced or serviced recently one thing that can smooth out the ride is to pull the spring packs off, take them apart and do a bit of work on the springs so that they slide against each other smoothly rather than binding up against the wear spots.
    I don't have time to hunt down or do a tutorial right now but the gist of it is that you smooth out the grooves that the spring above or below the leaf you are working on wore into the leaf so that leaf can slide smoothly and then round off the tip of the leaf that did the damage to the other one so it won't dig in again. Then after inspection and probably replacing the bushings in the eyes you lube it with your choice of lube and re***emble it.
    vtx1800 and warbird1 like this.
  12. Zax
    Zax
    So everything is new and completely stock? If anything is not stock, for example tube shocks or reversed eye springs, it's important to state that. Are those BFGs 6:00 x 16 Bias ply on stock wheels?
    The more info you supply the better chance you get good advice on what could cause the ride issues.
    Moriarity likes this.
  13. RodStRace
    RodStRace
    Please fill out the questionnaire
    What is the current suspension and how long has it been there?
    What do you find about it that needs improving? Be specific.
    What do you want after changes? Be specific.
    What is your budget/skill?
    Just Gary likes this.
  14. Clarification: do you mean you have Mustang 11, and CE rear and it rides rough, or you're thinking of changing to that from original to improve ride?
    putz likes this.
  15. Los_Control
    Los_Control
    from TX
    A pillow for the seat.
    Worn suspension in a 1 ton work van rides like a caddie, worn shocks just seem to float down the highway.
    New suspension & shocks is going to naturally give a performance vibe to the ride .... possibly carry some 80 pound sacks of cement in the trunk to work the suspension and it will ride smoother .... lower the air pressure in the tires helps ..... I suggest a pillow.
    Algoma56 likes this.
  16. choptop40
    choptop40
    Ch***is Engineering rear leaf kit were the popular go to suspension years back...still available
