History help to identify cam ID
Discussion in 'The Hokey Ass Message Board' started by BLACKNRED, May 28, 2010.
  1. BLACKNRED
    BLACKNRED
    I have an Isky Cam for 348/409 Chev with the following marks, stamped on the end, 9204 and RR360, on the other end engraved/etched is 18566.
    if any one can help it would be appreciated. I have tried Isky with no help.
    many thanks:confused::confused::confused::confused:
    grub
  2. Little Wing
    Little Wing
    from Northeast
    RR358 is a 348 Roller cam so guessing thats a 409 cam ( My catalog only goes to1960 )
  3. kadillackid
    kadillackid
    out of a 62 catalog
    Quote:
    RR-360 "Big Incher" Intake. 31-77 Exhaust. 77-26 Lift .445 Valve/Rocker Clearance .018
    58 to 61 348ci & 409ci
    For large displacement engines at high and sustained speeds. Provides terrific acceleration at engine speeds above 4000RPM. Should be used with stick or beefed hydramatic transmissions. Also a excellent cam for bored or stroked engines, racing at 1/4 mile drags, in light altered coupes or sedans and roadsters. :) obviously the same as the 358 as in Little Wings post!
  4. BLACKNRED
    BLACKNRED
    thanks guys, I am putting together a FH code 348 for my 61 Bel Air Bubbletop, I am nearly ready for****embly, and I needed to know whether or not the cam was going to be ok with a 700R trans.
    you have been of great help, many thanks again.:);)
    grub
