History HELP... Trying to identify Hildebrandt center bolt valve covers
Discussion in 'The Hokey Ass Message Board' started by 3wLarry, Apr 10, 2014.
  1. farna
    farna
    I'll check on the AMC Forum and get back to you... I don't have one at home.
  2. farna
    farna
    Got a quick reply -- Length and width (of AMC Gen1 327) is 21x5 3/8 and distance on holes is 9 1/2 center to center.
  3. 3wLarry
    3wLarry
    from Owasso, Ok
    Thanks Frank. Guess that rules out AMC.
    kidcampbell71 likes this.
  4. Louie
    Louie
    from NJ
    these fit right on a 324 head
  5. I think that you got it here and the lumps are so you could run Stude adjustable rockers.
  6. kadillackid
    kadillackid
    Catalog lists only Chev, Olds and Cad :confused: HildebrandtCatalog_0011.jpg
  7. 3wLarry
    3wLarry
    from Owasso, Ok
    That's it!! Who knew a 324 and a 303 valve cover were different? Thanks Louie
  8. GOATROPER02
    GOATROPER02
    from OHIO
    Olds are all the same bolt spacing.... 1949-58
    10 3/8 c to c
    303^
  9. GOATROPER02
    GOATROPER02
    from OHIO
    371^
    Yours are 10 1/8 or 1/4 off
    And they do not match the heads..... 1 bolt installed and this is where they locate ImageUploadedByH.A.M.B.1397569430.597773.jpg
  10. GOATROPER02
    GOATROPER02
    from OHIO
    This is what an olds head looks like
    If the cover was the correct length ....
    Here is where the gasket would lie
  11. GOATROPER02
    GOATROPER02
    from OHIO
    Here you have examples to the ones in question...,.
    Bottom two stock and aftermarket 371 covers
    Middle stock and aftermarket 303-324 covers
    All have same radius's on the ends top and bottom.....
    Top is cover in question.... As you can clearly see... Radius's are not the same and will not seal on the head
  12. Martin_F
    Martin_F
    ^^ Love me some dimples!
  13. stillrunners
    stillrunners
    from dallas
    Stude....you can run all four....run just the out side....or.....just the inside....
  14. titus
    titus
    Tony,
    I also have a set of the hildebrandt covers that are supose to be olds, my bottom flange looks the same too and bolt center to center is 10-1/8.
    I have a set of cadi valve covers (50 up type with 4 outer bolts) and they are alot longer than olds, i would ***ume the 49 cadi has the same length valve cover as 50 and up cadi but cant say for sure, so we basically need someone to measure the length and center to center of the 49 center bolt cadi so see if thats what these fit too.
    (edit read in an earlier post that the 49 cadi had a 14" center to center pattern)
  15. 55 dude
    55 dude
    great thread!
  16. titus
    titus
    But,
    One thing i have to disagree with you about Tony is the length, if you put it on one bolt like you did its going to offset it way the one way and not work, i just went out and popped the cover off of a 303 im working on at the moment and to the brand new fel pro gaskets and held them up to the covers, sure its not ideal but they will work and seal just fine, the patterns to me were just poorly made, the mounting holes will also need to be enlarged a few sizes, i took the valve cover to the 303 head that has studs in it and kinda put it over one stud and then pulled it over a little and it popped over the second stud with very little effort and when on both studs centered up just fine on the head, so when the holes are opened up a little they will slide right on.
    i know the corners on the covers are cuttig it close but if you look at the material where the bumps are there really isnt any more there than on the corners
    jeff
  17. titus
    titus
    brought the hilde cover back out and stuck it on the 303 and marked the over hang, about 3/16 per side with a light 1/4" of sealing surface still on the ends.
    Again, not ideal but would still work fine.
    So to recap, they are olds, they were just poorly patterned and fit. maybe they were hoping for more shrinkage.
  18. 550Coupe
    550Coupe
    I have those same valve covers on my 371 Olds engine. Rather than slotting the holes, what I did was make up new studs with a slight offset. Loc***e the threads where they go in the head so they stay in position, and you're done.
  19. titus
    titus
    Good idea there too.
    I have a set of repop nailhead valve covers that were made wrong and thats what i was planningon doing with them too.
    jeff
  20. 3wLarry
    3wLarry
    from Owasso, Ok
    Thanks Jeff for the clarification. A lot of guys have been telling me that they had to be Olds because Hildebrandt only made valve covers for three engines...SBC, Caddy, and Olds. And Olds was the only one with center bolt holes.
  21. GOATROPER02
    GOATROPER02
    from OHIO
    I agree with poor castings and machine work that may have happened in the day...... While you can lay an Olds gasket on and it appears all is well...... When it is centered on the head and one can see an obvious gap where the it does not even cover the head on each end..... And the the bolt pattern being that far off.... And the cover is used without any sign of abuse.... Trying to get the bolts in..... You have to wonder....
    Now.... Will a cork gasket squeeze in there and seal?? Probably....
    Can one get them on Olds heads and keep the oil in.... Sure...... Can you beaver the holes out or use offset studs... Of course
    Will I have to work on them with a tig welder ...add some material and resurface them ..YES
  22. GOATROPER02
    GOATROPER02
    from OHIO
  23. slimpick
    slimpick
    Foundryman made an incorrect shrink factor calculation.
  24. alchemy
    alchemy
    The PATTERN man made an incorrect shrink factor calculation.
    I bet you have an early production piece that was changed for a better fit pretty soon after Hildebrandt started getting them back in the mail.
  25. titus
    titus
    Tony,
    Mine fit my heads way better than yours, with no gap, so your set and mine must be a little different also.
  26. stillrunners
    stillrunners
    from dallas
    dang....wrong again.....(but was hoping they were going my way for a little Studie)...
