And I keep getting this messege when I hit preview You have included too many images in your signature or in your previous post. Please go back and correct the problem and then continue again. Images include use of smilies, the vB code tag and HTML <img> tags. The use of these is all subject to them being enabled by the administrator. I have 17 pics in it and all are hosted on photobucket.
I ran into this with my tech post. you need to break it into several post. I think I got 5 or so pics per post. I usually put mine in a WORD do***ent and copy portions to each. SO post a portion and submit, then post the middle section and post and then the third section.... or 4th if necessary. The reason I post it in a Word do***ent first is because it makes it easier to copy only what you want and not loose the rest.
