help! turn sigs light don't flash
Discussion in 'The Hokey Ass Message Board' started by larry woods, Mar 22, 2012.
  1. larry woods
    larry woods
    from venice fl
    I had signals on my coupe and all of sudden didn't flash. I ***umed flasher replaced it and same problem. Respective lights will light but not flash. Switch is column mount aftermarket. I have researched but nothing on point. Bad ground? but why light up? bad switch? thanx for your help. larry
  2. specialk
    specialk
    Bad grounds do bad things to flashers
  3. F&J
    F&J
    It sounds like you mean that the signal filiments on each side will light up bright, but not flash ?
    That sounds like a defective new flasher, or a very heavy duty flasher that needs more bulbs to make it trip.
    A flasher is just a self resetting circuit breaker, the light bulbs come on and cause a draw, and the bimetallic strip switch in the flasher heats up and breaks the contact, then cools to reconnect again.
  4. johnboy13
    johnboy13
    From what I understand, the power goes through the flasher to the switch, which determines the direction the power goes from there. If the lights get power and light up, I wouldn't suspect the switch or the grounds to the individual lights. Does the flasher have three blades or two? If it's three, the third blade is ground. If it's two, use a circuit tester to check the flasher. Connect one prong to +12V, connect the clamp of the circuit tester to the other blade, touch the other tip of the circuit tester to ground, the light on the tester should blink and you should be able to hear the flasher click.
  5. 37_chevy
    37_chevy
    from Nebraska
    Are there any dual filiment bulbs involved? Make sure one filiment isn't touching the other and causing problems. Check all the bulbs as feedback from one can cause wierd things.
  6. Comet
    Comet
    Same thing happened last week on my truck. Bad ground was the culprit.
  7. add more fluid :)
    sorry, I agree with the bad flasher comments- and follow the wire/ground!
  8. Old Rod
    Old Rod
    from Brazil, IN
    Happened to me last spring, after all checking, BAD GROUND.
  9. Lobucrod
    Lobucrod
    Alliance Vendor
    from Texas
    You didn't happen to replace any bulbs with LED's did you? LED's dont pull enough current to make the flasher work.
    And the third terminal on a three prong flasher is not a ground terminal, its for a pilot light. Some cars and trucks only had one pilot light on the instrument panel that flashed with the turn signals. Also the add on blinker switches usually use the three prong flasher since they have one built in pilot light.
  10. burnout2614
    burnout2614
    ALSO Does your wiring system include a separate flasher for the hazards? If so you may have replaced the wrong flasher. The first flasher I see is usually for the hazards! G luck. peace
  11. johnboy13
    johnboy13
    I guess I should have been clearer, if it's a modern, relay style, three prong flasher, the third prong is ground.
  12. bobss396
    bobss396
    Look for a bad bulb as well, that can make you nuts. If you have a spare one, swap it around until you find a bad one or not.. then it's something else.
    Bob
  13. larry woods
    larry woods
    from venice fl
    Yup! it does I did! Thanx for the clue! They are now functional and I feel appropriately stupid! At 70 you can still learn something new! I appreciate all the responses! larry
  14. 325w
    325w
    No reason to feel stupid...........At 70 I bet we all could learn a bunch from you.
    325w
    66+
