help Uploading pictures from photobucket
Discussion in 'Questions & Suggestions' started by wide34, Mar 12, 2010.
  1. wide34
    wide34
    from Texas
    I'm trying to upload pictures from photobucket by copying the image code and pasting to the URL. I keep getting an invalid file message. What am I doung wrong?
    Thanks
  2. BrandonB
    BrandonB
    from nor cal
    When you figure it out let me know. I have the same problem.:confused:
  3. HOTRODPRIMER
    HOTRODPRIMER
    Whats your photo bucket site?,,I'll see if I can post from it. HRP
    Went to mine and checked,,,use the IMG CODE,,
  4. K13
    K13
    Make sure you remove one of the http:// from the beginning of the URL code. The HAMB automatically adds one on when you select the little mountain picture tab and there is one attached to the URL from photo bucket. Unless you scroll back to the beginning of your link you would never see it doubled and it will not allow the image to load with two of them there.
  5. you need to copy the image code not the url
  6. wide34
    wide34
    from Texas
    I really appreciate the help but maybe I am too dense to make this work!
    I've tried eliminating the http:// and tried the html code but still get the same error message. Think I'll see if my grandson can figure out what I'm doing wrong!
  7. HOTRODPRIMER
    HOTRODPRIMER
    Go to your photobucket sight and choose the photo you want to post..
    Drag cursor down tuntill the 4 options pop up,,
    Email & Im
    Direct link
    HTML code
    IMG code <------use this one
    For posting on the HAMB
    Left click your mouse on the IMG code,,it should hi-light in blue.
    Right click to copy.then left click to attach,
    after you compose your thread for what you need to say,,simply right click and you should see undo ,paste and delete,,just left click on paste and you should have a photo. HRP
  8. HOTRODPRIMER
    HOTRODPRIMER
    BTW,,photobucket automaticaly resizes your photos so you don't have too. HRP
  9. wide34
    wide34
    from Texas
    I've been able to copy the picture on photobucket and simply paste it into the message section successfully. I did have to reduce the size but otherwise it worked. I hope that helps you, it sure is confusing and nothing anyone else told me worked!
    Tom
  10. the DutchDude
    the DutchDude
    [​IMG][/IMG]
    this is what i get,,
    i left the http out,, and when i leave it ,it doesn't work also,,
  11. the DutchDude
    the DutchDude
    sorry for the big picture ,but it works,,
    i use photobucket ,,shouldn't it be smaller??
  12. Arrgh!!! I can get a pic in the regular thread posts. But I'm trying to get a pic in a social group post so this may make a difference. I have tried all the suggestions and still get the red x. I went in and copied the url - no go, I got the img link - no go. Guess I'll try to copy the actual pic and see what happens.
    So I copied the pic and it went here. Now to see about the social group. didn't know it would be so big tho.
