Technical Help w/ Camel Hump Head GM Motor
Discussion in 'The Hokey Ass Message Board' started by custom_line, Jul 13, 2017.
  1. custom_line
    custom_line
    from Las Vegas
    Hey there.. sooo.. Im having difficulty id-ing exactly what this motor is.. and how much I should sell it for.. GM casting #3782870 Engine Code F0422S and the Intake # 3844459. I know its a 62-65 327..but outta what? Is it corvette? But to sum it up..what would you sell it for? Or what would you pay for it?
    Sorry for dumb questions..but value your input
    Thanks
  2. Sheep Dip
    Sheep Dip
    from Central Ca
    Block number is 62-67 327
    Intake number is 64-65 300HP could have been Corvette but not exclusive to it
    What are the head numbers including the cast dates?
    I recently sold a complete similar for $300
  3. timwhit
    timwhit
    If it doesn't run, from a buyers stand point, it's a core. Price will vary.
  4. ididntdoit1960
    ididntdoit1960
    from Western MA
    1962-1964 250hp 327 from a full size pg equipped car used the S suffix......not sure if the heads are right though, pretty sure 250hp used power pacs and smaller base carb......need casting numbers and dates
  5. custom_line
    custom_line
    from Las Vegas
    Head # 3880462 L 2 6
  6. custom_line
    custom_line
    from Las Vegas
    Right? Cause it could just be a super cool boat anchor... what would you pay for it?
  7. jimmy six
    jimmy six
    They are all Corvettes...every seller knows that..
  8. ididntdoit1960
    ididntdoit1960
    from Western MA
    looks like 66 heads swaped onto a 64 block (can now see the casting date in your pics)
  9. treb11
    treb11
    need the stamped code off of the right front deck.
  10. timwhit
    timwhit
    I just sold a 283 to a friend. Told him to have it checked out, then if it was buildable we exchange money. That is hard to do with a stranger or someone out of town however. Wish I had a 327 to build!!
    325w likes this.
  11. timwhit
    timwhit
    Add this to mu above post, forgot to include it.
  12. Mr48chev
    As it sits with not knowing what shape it is inside including how much water got down the intake while it sat outside giving 100 bucks for it would be a gamble playing the odds that it was rebuildable. I'm not a fan of buying engines torn apart but this time I think that if you want any money out of it over basic parts house core price you need to tear it down and make sure that the heads aren't cracked, Make sure that it didn't get blown up or be broken internaly and make sure it didn't fill up with water and rust the **** out of everything. Worn to the point it needs bored, not an issue, needs a full and complete valve job including guides not an issue. Who ever really wants that engine will go clear though it anyhow but from what the others said it isn't some holy grail special editon 327 that commands big bucks from some collector.
    Work In Progress likes this.
  13. Sheep Dip
    Sheep Dip
    from Central Ca
    The problem with the older iron (if you want to call it that), is that unless you are looking to correctly restore or build correct, the machine work is so expensive,... and I totally get that it cost money.
    Some guy's have the means to do their own, but to the guy like me that just wants a driver with a little pep, you can buy a 4 bolt crate motor complete long block for the price of just a rotating ***embly by a reputable machine shop.
    So as has been stated unless you find that special gotta have it buyer...it's a core.
    A year ago my son ordered a 290 HP 350 4 bolt long block from Jeg's...$2000 and free shipping. Runs Perfect.
  14. 327Eric
    327Eric
    I would pay 50 to 200 for it and sell it for about 350. The last one i did was a free, virgin block cast in november 1961. It cost about 1600 to do a stock rebuild with a l79 cam and 2.02 valves.
  15. INVISIBLEKID
    INVISIBLEKID
    from Gilroy,CA
    I have to agree with this ^
  16. custom_line
    custom_line
    from Las Vegas
    I've got a few 327s... I think I hear them calling your name.. "Tiiiiiimmm"
    come take your pick [emoji6]
  17. sunbeam
    sunbeam
    That flywheel flange is 65-67 327.
  18. timwhit
    timwhit
    Wish we were cl
    oser.
  19. Hot Rods Ta Hell
    Hot Rods Ta Hell
    Depends on what shape it's in internally. You'll need to dis***emble it a bit to know. Is it a good core or junk?. Maybe it's already .030 over-(or more). As 48 chev said; pull the heads for inspection and mic/inspect the cylinder walls. Any prospective buyer will be asking you to do this or be asking if he can pull the heads on site before exchanging money.
  20. If its not locked up. Pull the oil pan and you can measure the bore from the bottom. then take a look at the bearings. If they are not showing copper. put it back together and get it running. It aint gotta be in a vehicle to run. rig it up to hold water and hook up a oil pressure guage. A starting running 327 should easily bring $500. As it now is you would be lucky to get that $100 .
  21. Kan Kustom
    Kan Kustom
  22. custom_line
    custom_line
    from Las Vegas
    10/4... and should I hold my breath for the special buyer? Or would I end up dying first?
  23. Sheep Dip
    Sheep Dip
    from Central Ca
    You can advertise on some of the forums like Chevelle, Camaro, Nova and Corvette or Craigslist even.
    I got lucky on mine as I knew a fellow with a 64 Chevelle who needed an era correct block so he took the whole enchilada, but at "Core" pricing.
