help water spraying from radiator over flow
Discussion in 'The Hokey Ass Message Board' started by 29moonshine, Mar 4, 2013.
  1. 29moonshine
    29moonshine
    i have a 350 in a 32 ford with a griffen radiator and a 23 # cap .when it starts within a few minutes water starts spraying out of the over flow at the top of the radiator. it is a steady stream all the way across the blower to the fire wall .
  2. Gman0046
    Gman0046
    23# cap seems pretty high.
  3. BJR
    BJR
    Is the radiator supposed to have a remote expansion tank? If not are you over filling the radiator? 23# cap is way high, should be around 15#. I would try a different 15# cap. The one you have must not be sealing correctly.
  4. n847
    n847
    What he said plus an overflow/expansion tank. Thats what fixed it for me.
    Sent from my DROID device using the TJJ mobile app
  5. 29moonshine
    29moonshine
    i went from a 15 # cap to the 23 thinking the cap was weak. it is pumping water out until you turn the motor off. not just on start up
  6. Test the coolant for exhaust g***es...
  7. BJR
    BJR
    Have you changed the pulleys? If not a head gasket, the water pump could be over driven. Flowing more gallons per minute then will flow through the radiator core. It has to go somewhere so it blows the cap.
  8. 29moonshine
    29moonshine
    will do that tomorrow
  9. rad cap and rad w/overflow exp tanks are two separate types
    show us the cap in question
    exp tanks caps typically do not have the old style ears(are round) and open and close as needed ... to keep air out of the system
    the rad cap style just opens when pressure is reached
    both could be lever type ...
    my theory ?
    the new rad is designed with a return system neck and you are using the old style cap which does not block off the return /overflow tube at all
    thus pissin all the time ....
    rad cap testing can help if you have the right one for the neck being used,
    if it is a blower car timing is a big issue with absorbing heat get that sorted quick before parts fail
    have a separate switch for ignition so timing is not an issue at start up
    and a very good waterpump not depending on an over spun belt drivin unit
  10. southcross2631
    southcross2631
    You could have air trapped in the back of the motor.My small block g***er had that problem .I would have to jack the front of the car up as high as I could get it before it would burp the air out and then everything would be fine.
  11. tjet
    tjet
    The expansion tank mentioned above is only needed if the radiator cap is too low (like in a vette). Make sure your cap is the highest thing in the cooling system (including heater hoses)
    Some of the newer thermostats lack a piddle byp*** valve. This was a small hole in the side of the thermostat that allows water to byp*** a closed thermostat.
    You can drill a 1/8" hole in your thermostat, which will do the same thing.
    I think this will fix your problem
  12. henry29
    henry29
    I've never heard of that, what did they do for factory no heater cars?
  13. 29moonshine
    29moonshine
    it is has a blower on the motor. it will start blowing the water out within a minute of running time. hot or cold the radiator and cap worked good in the 30 chevy. it is setting lower in the 32 than it was in the 30 chevy
  14. Country Gent
    Country Gent
    In a "Few Minutes?" Could be a blown head gasket!! I had the same situation once. Engine ran fine, buy would build up pressure. Take the cap off, run it and see if it is bubbling or foaming
  15. shinysideup
    shinysideup
    from ruskin, fl
    Popped that head gasket pal.
  16. BURN OUT BOB
    BURN OUT BOB
    from western AZ
    How good is the thermostat?
  17. Okatoma cruiser
    Okatoma cruiser
    from Ms
    Remove water pump belt- remove thermostat and thermostat neck. Crank engine and watch for bubbles - if head gasket is leaking it'll show
  18. n847
    n847
    I think we need pics or a video. Maybe you could contact Griffen. It still doesn't sound like something more severe than needing an overflow/expansion tank. What is the temperature topping out at?
  19. HOTRODPRIMER
    HOTRODPRIMER
    How about a few photos?,,is the car running hot?
    What kind of fan are you using? Pulleys? HRP
  20. 29moonshine
    29moonshine
    it has a stock 5 blade fan off of a 66 nova and short wp. if you pull the cap off the raidator it starts pumping the water out within a minute [ before it gets to 150]. i pulled the thermostat out still does it . i pulled the heads and the head gaskets looks good. i had the heads checked and no cracks put it back together with new gasket and it is still doing it
  21. n847
    n847
    So is the water coming out an overflow tube or past the cap?
  22. Bigchuck
    Bigchuck
    from Austin, TX
    No. Does not cause a problem.
  23. 29moonshine
    29moonshine
    overflow tube
  24. larry k
    larry k
    be real careful with a 23LB cap on a griffin radiator ,i think those have a bonded header plate,, ??? not a welded one it will be easy to blow that out... ! and i here that it is hard to get them repaired,if they are the bonded ones.?
  25. once too much prssure has been applied to the alum rad it will self expand the soft fins and have little flow through ....squeeze the tube openings closed
    ... dang it sounds like its what happened
  26. n847
    n847
    I would run a lenght of hose off of the over flow into a container on the floor so that the hose end is at the bottom of the container and will stay submersed. Let the car run and puke all it wants till it gets up to temp, and see if it actually over heats. When you shut the car off it should **** the water back into the radiator (I think it will do this with out a sealed tank). Mine spits water into the tank every time it runs but never over heats then ****s the water right back up into the radiator when shut off. My understanding is that this is perfectly normal.
  27. olklunker
    olklunker
    I know this sounds like a very simple fix, but I've seen the same kind of problem caused by using an incorrect water pump. A friend once used the water pump off a newer small block, one that used a Serpentine belt. He simply changed he pulley and bolted it on. What he didn't realize was that the Serpentine belt ran the water pump in the opposite direction. Instead of pumping water from radiator to engine, it was pumping from the engine to the radiator, overfilling the radiator and causing excessive pressure to build up. He blew the top hose once and split the radiator twice before the counter man at Auto Zone came up with the solution (I know--hard to believe, huh?). Just my $.02. Good luck with your trouble shooting.
    Jerry
  28. HOTRODPRIMER
    HOTRODPRIMER
    This makes sense,,are you sure you don't have a serpentine water pump? HRP
  29. chevyburb
    chevyburb
    I agree with n847 for what it's worth!
  30. 29moonshine
    29moonshine
    would that perssureize the raidator before it gets hot? i just pulled the motor down and sent it to the shop to be magnafluxed. [going to be pissed if it is the water pump]
