Hot Rods Help! What size pleats for a '60's interior?
Discussion in 'The Hokey Ass Message Board' started by R. Seghi, Feb 23, 2013.
  1. R. Seghi
    R. Seghi
    I need help getting the right size pleats made for my interior. I'm building a '55 Chevy G***er with a late '60's theme. Interior will be black vinyl pleats so I need to figure out what size should the pleats be? Anybody know?
  2. BOBCRMAN
    BOBCRMAN
    from Holly
    I did a lot of 2" back in the day
  3. 56premiere
    56premiere
    Some 1'' ,11/2, 2''.2 was probably the most chosen.If doing back sewn, each line takes about 1/2'' extra material which really adds up.My Lincoln is 2''. Jack
  4. ccrodder
    ccrodder
    1.5" to 2.5"...depending on thickness and density of pleating foam used.
    Keep in mind that the thicker/denser the foam, the more it will shrink the width of pleats after its sewn.
    A common rule of thumb is to add half the thickness of the foam for each pleat sewn.
    For example if you want 2" pleats and your using 3/4" foam add 3/8"...draw your pleats out at 2 3/8".
    This applies to simple top s***ch pleats, tuck and roll pleating as well, but the layout and sewing process is somewhat more involved.
    *Thickness/density will dictate how defined the pleat will stand out.
    *Also make sure your pleating foam has a backing such as muslin, this prevents the s***ching from pulling or cutting through.
  5. USA Tires Sign Joe
    USA Tires Sign Joe
    from Western NJ
    A finished product with a 2" pleat will look great!
  6. chopped
    chopped
  7. Mark in Japan
    Mark in Japan
    Weren't they onto Diamond Pleat etc by then?
    Or Rectangular Pleat with metal 'breather rings' like GT40 etc?
  8. R. Seghi
    R. Seghi
    I used a 2 1/2" pleat
