Help-what welder do you recommend?-equipmnt
Discussion in 'The Hokey Ass Message Board' started by bad4587, Oct 14, 2007.
  1. bad4587
    bad4587
    I am looking into purchasing a welder for my build and was hoping if you guys can shed some light as to what type of welder I should use for some sheet metal & moulding work, nothing to overkill but enough to get the jobe done right. I've done "some" welding years ago and will definitely need to practice a bit, I'm sure it'll come back to me, I hope!! Any brand names, size and ball park figure on price? Thanks in advance for your time and comments, greatly appreciated!!!
  2. sawbuck
    sawbuck
    from 06492 ct
    hobart handler 187 mig. you can build the frame and do the sheet metal work.650.00.best deal for the $
  3. GirardsSpeedShop47
    GirardsSpeedShop47
    Nothing against the Hobart, I would look into a Lincoln 135 MIG welder. It is built for a 110 outlet and will have more than enough power for what you are using it for. I own an old Lincoln 100 and I love it. I have had it for 5 years.
    I also suggest the lincoln because you can get parts for it a little easier. Every Welding store has parts and stuff for a Lincoln and or a Miller. I also know Miller makes a little wire welder too.
    Good Luck with what ever you get.
  4. Joe King
    Joe King
    I'm no welder but even I can use the 140 miller I just got
  5. TagMan
    TagMan
    Yep, I agree, I LOVE my HH187 !!;)
  6. slddnmatt
    slddnmatt
    i love my 185 miller, just realized the other day ive been using it for 10 years!!
  7. 392_hemi
    392_hemi
    I recommend you try the search function. This has been covered about a hundred times.
