Help...What year is this Ford column drop...'34-'40?
Discussion in 'The Hokey Ass Message Board' started by 3wLarry, Oct 16, 2012.
  1. 3wLarry
    3wLarry
    from Owasso, Ok
    Not real sure what year this puppy is...
    kidcampbell71 likes this.
  2. racemad55
    racemad55
    Don't have a clue myself, but if **** Spadaro sees it he will know.
  3. 3wLarry
    3wLarry
    from Owasso, Ok
    yeah, but its past his bedtime...:)
  4. cvstl
    cvstl
    from StL MO
    '37 - '40 range..... I think. That narrows it a little. The switch handle is the same as my '40 column (different than the my '37).
  5. madpole
    madpole
    the switch also looks the same as my '41.
  6. Andy
    Andy
    Looks like a 1940 to me.
  7. -Brent-
    -Brent-
    I don't know, but is it for sale???
  8. 39 Ford
    39 Ford
    40 is to newfangled for me but I would think a 40 would have a place for the Column shift shaft. Without loking at my car I would say 38-39.
  9. gas pumper
    gas pumper
    Does this have a formal name in Fordlandia?? A better description than column drop. Column support? Ignition switch? steering lock? In other words If I was looking for one, what would be the right name for it?
  10. olscrounger
    olscrounger
    40 ford-for a car --column shift-want to sell--it PM me THX
  11. Bruce Lancaster
    Bruce Lancaster
  12. HOTRODPRIMER
    HOTRODPRIMER
    Larry,,I had to go through all my saved images to try and help but I'm pretty sure the drop you have is a 40 Ford,,
    This is 38-39,,
    Don't have any photos of 36-37
    This is 33-34,,HRP
  13. jefscoupe
    jefscoupe
    Hmmmm. Mine looks similar to the 40, yet different.
    This was in my 32 when I got it. It had been brazed to the dash, luckily, so it came off relatively easily.
    The key is broken off in the lock. Can anyone tell if it's in the on or off position? I can get pliers on it and it moves a little, but won't come out.
    What do (did) the switches do? Was the key just to turn on the ignition?
    Starter ****on on the floor? What was the toggle for?
    Is that another ****on or something on the right side (first pic), the round knob-looking thing off the toggle switch?
    One more: How does it come apart?
    I've been soaking it in penetrating oil for a couple days now.
  14. 296 V8
    296 V8
    from Nor~Cal
    Key unlocks the column and switch .... (yes not GM’s idea)
    Switch turns ignition on and off
    ****on on dash grounds the solenoid - sending power to the starter motor
  15. jefscoupe
    jefscoupe
  16. 345winder
    345winder
    i have a question about column drops..i have a 34 im building and it is missing and i need to find one that i can make work...
    .......is the inside diameter of the drop the same from 1932-40????
  17. jefscoupe
    jefscoupe
    I believe so. I'm sure someone with more knowledge will chime in though.
    I'm using 1 1/2 inch exhaust tubing for my column.
  18. 296 V8
    296 V8
    from Nor~Cal
    Id not be surprised if 32 is a different diameter …. ******* of a car that it is
