Help with 12v generator
Discussion in 'The Hokey Ass Message Board' started by ROCKIT, May 4, 2012.
  1. ROCKIT
    ROCKIT
    My car currently runs an early 6v generator which has been converted to 12 volts, this unfortunately has a paltry output and it would appear is unable to supply even enough power to power the ignition. Now it may be that the control box may be at fault. Before I go through the whole thing, I have a question.
    Is there an original 12volt generator that Is a direct replacement for the one I have now? If so what year and model would that be from?
    I do have a Powergen alternator but I would rather stay with an original style generator.
    Any help is appreciated.
  2. Dirty Dug
    Dirty Dug
    I used on from a late '50 to early '60 Ford pick-up, had to drill a hole for it to mount on the stock 8ba generator mount but other than that is was a direct bolt on with a wide belt pulley. That may not work for you because I just noticed your fan is mounted to the generator.
  3. Jack E/NJ
    Jack E/NJ
    from NJ
  4. tommy
    tommy
  5. Mr 42
    Mr 42
    from Sweden
    I have a 6to 12 Volt converted generator, it gives out 30 amp Max.
    And works great with all lights on. all the time.
    Take it to a generator shop to have it cheched out.
    Had a Bosch 12 Volt flathead generator, there i had do chose lignition and lights or ignition or heater. It gave only 130Vatt (10Amps). So 30 amp is OK.
