Help with 36 Ford Pickup Door Regulator
Discussion in 'The Hokey Ass Message Board' started by Crazy8, May 22, 2012.
  1. Crazy8
    Crazy8
    from KY
    I am trying to figure out the door regulators on my 36 ford pickup. The picture I Have is what I think is the drivers side, but I can not seem to get the track set correctly in the guides of the regulator.
    Does it look like the arms in the correct position in the down direction if the window was in the down position?
    Thanks
    Jeff
  2. Perrorojo
    Perrorojo
    I turn mine counter clockwise to roll the window up. ***uming yours is the same I would think what you have pictured is the p***enger side. Is the problem that the track falls out when you run it all the way down?
  3. Crazy8
    Crazy8
    from KY
    Yes that is a problem I having
  4. Perrorojo
    Perrorojo
    I think what you have in the picture is in the "up" position. I have a set laying around in the shop, I'll check it out tomorrow and see what they look like.
  5. Perrorojo
    Perrorojo
    Here is the drivers door mechanism.
  6. Perrorojo
    Perrorojo
    Your picture is showing a p***enger door mech in the up position.
  7. Crazy8
    Crazy8
    from KY
    Thanks. That helped.
  8. RICH B
    RICH B
    Remember that both of the springs wind up when the gl*** is lowered, if your picture
    is a p***enger side regulator rolled up the rusty spring is on the wrong way.
  9. tnich123
    tnich123
    Man guys as soon as you get this figured out I can make mine work. I have it in the door and the gl*** hooked to it but as soon as I roll it all the way down it jumps out of the track. I think I am going to put a small screw in it to make a stop depending on how far the gl*** goes down???
  10. trollst
    trollst
    Maybe you guys know, maybe you don't. The first quarter turn moves the gl*** backward in the guide before it rolls down, it moves the gl*** back about an inch, creating a draft, then rolls down into the door. There should be a stop mechanism in the slides inside the door, there is a pin on the bottom gl*** track that fits a slot in the regulator, which is bent outward to grab the pin on its way up. From the bottom, fully open, the window will crank all the way up, the pin is grabbed by the regulator and the last quarter turn pushes the gl*** toward the windshield, sealing itself in the window felt. Don't know how else to explain this, hoping you understand, it took me some time to figure mine out.
  11. DICK SPADARO
    DICK SPADARO
    Your picture is of a P***enger side regulator that you are attempting to install on the driver side. Check procedure, Place the regulator crank handle on the left horizontally, wind regulator so the lift arms are pointing vertical up, the slide groove should be in position between the lift arms an the large hole in the slide gear fully exposed. That is Right side unit. If it is a Left the arms will not go vertical and the hole is partially covered
  12. Perrorojo
    Perrorojo
    he is smarter than me ^^^^
  13. Crazy8
    Crazy8
    from KY
    So i took a few more pictiures. The one I am holding on the door is the regulator all the way up and the pin in the round guide slot is in the up lock position. The othere two pics is where I am not sure if correct.
    One is the regulator is half way down and the pin is about to come out of the round guide slot. The other is where the wiondow would be in the lowest position but the pin is now out of the round guide slot.
    So if the window is in the lowest position should the pin be out of the guide and the gl*** side guides guiding the window so when it is cranked up is will be guided back into the round guide slot?
    Thanks
    Jeff
  14. trollst
    trollst
    Yes, at the lowest position the pin is not in the guide, it engages on the way up.
  15. tnich123
    tnich123
    At one time I thought I had this figured out but now I am more confused? When I roll the gl*** all the way down and then try to roll it back up the pins doesnt grab the regulator coming back up. I didnt know that the gl*** slides back an inch as it is going down. I will have to look at mine again. I got so pissed after spending a couple of hours on the drivers door and beating my hands up I took the gl*** back out until I understand better what I am doing!!! For some reason I get the feling that this isnt as hard as I am making it?????
  16. trollst
    trollst
    Took me three days to figure it out, the regulator slot has a peculiar bend in it, on the way up, it lines up with the pin on the bottom gl*** track and the pin slides neatly into the slot. You'll notice the door doesn't have a vent window, when you first wind the regulator, the window moves straight back toward the door handle about an inch before going straight down, the reverse going up, goes straight up till closed at the top, then moves toward the windshield the final inch. Great no draft system, works very well, keep playing and you'll make it work, wish we were closer, I'd show you mine.
  17. Crazy8
    Crazy8
    from KY
    What's the best way to cut a template for the side gl*** if you have to in for the shift when it is rolled up. I also have a 5 inch chop on mine.
    Jeff
