Technical Help with 42-48 Buick tail lights
Discussion in 'The Hokey Ass Message Board' started by Dino 64, Nov 4, 2020.
  1. Dino 64
    Dino 64
    from Virginia
    D5D9E76F-20CC-45DC-A9AF-83B0A4FC4E6F.jpeg 2D389C93-5B93-4256-989D-BE185F2A3007.jpeg 38234DEF-83B5-41ED-BC0B-0238F040A9FD.jpeg 56922274-21F4-4BDD-8B02-8BD009A8E89C.jpeg 11C72947-32DF-49F3-BCE4-DCCBE7915E53.jpeg So I’m using these on my A coupe. The bezel and lens are repos but the backing plate is original.
    Does anyone have pics of this ***embly complete so I can figure out what I need to do to restore them.
    Pics are all the pieces I have. I pieced it together the way I think it might go together. Any help would be appreciated.
    Thanks
    Just Gary likes this.
  2. lothiandon1940
    lothiandon1940
  3. HOLLYWOOD GRAHAM
    HOLLYWOOD GRAHAM
    from Ojai,Ca
    I wish somebody would repro those.. ( Spell check put report instead of repro, got to proof read everything these days)
  4. -Brent-
    -Brent-
    Dino, when I have a moment to get back to my shop, I will get you some pics.
    lothiandon1940 and Dino 64 like this.
  5. Dino 64
    Dino 64
    from Virginia
    Thanks ^^^^^:)
    lothiandon1940 likes this.
  6. lothiandon1940
    lothiandon1940
    ........................o_O:confused:
    Dino 64 likes this.
  7. Dino 64
    Dino 64
    from Virginia
    Must be a West Coast thing ;):D
  8. lothiandon1940
    lothiandon1940
    .......I'm guessing he meant to say, " repro ":)
    Just Gary and Dino 64 like this.
  9. BJR
    BJR
    You have everything but the bulb sockets, which are deep and just the gl*** bulb sticks through the holes in the backing plate. A single filament goes in the raised hole and a dual filament goes in the round end.
    Just Gary, lothiandon1940 and Dino 64 like this.
  10. Dino 64
    Dino 64
    from Virginia
    Thanks @BJR, so the raised one is the blinker ?
    Do the two clips hold the socket on the larger round hole ? Not the raised one.
    Thanks very much :):)
    BJR and lothiandon1940 like this.
  11. BJR
    BJR
    Yes the raised one is the blinker. Each socket has it's own spring clips like your pictures, the raised one needs the clips re bent to hold the socket in. But you could get sockets that snap into the holes and not use the spring clips. You can also make either holes the blinkers or both just by getting double filament sockets, or moving them around.
    Dino 64, Just Gary and lothiandon1940 like this.
  12. Dino 64
    Dino 64
    from Virginia
    Thanks BJR, Appreciate the help :)
  13. BJR
    BJR
    Also paint the reflector side white for more light.
  14. Dino 64
    Dino 64
    from Virginia
    Good advice, thanks ^^^^
  15. -Brent-
    -Brent-
  16. Dino 64
    Dino 64
    from Virginia
    Thanks for the pics !!! Appreciate you taking the time to post them. Now it all makes sense !
    Thanks:):)
  17. -Brent-
    -Brent-
  18. Dino 64
    Dino 64
    from Virginia
    Hey, that’s great, I was trying to find parts online with no luck. Looks like you have lots of extra parts too. Thanks again
  19. -Brent-
    -Brent-
    I do have some extras. I had rough ones, at first, then came across good chrome single, then another, and now I have enough to make myself a nice set for my coupe. I haven't yet gotten as far as fitting sockets and wiring, yet.
    Here is my back panel on my A coupe.
  20. Dino 64
    Dino 64
    from Virginia
    Cool !! Here’s mine 6128F7F1-EDED-4A24-975A-AB69D1421A2F.jpeg B233B86A-8E94-4ADA-8CA8-E755CD88B96D.jpeg
  21. HOLLYWOOD GRAHAM
    HOLLYWOOD GRAHAM
    from Ojai,Ca
    See correction on my thread.
    Dino 64 and lothiandon1940 like this.
  22. Hunter Dixon
    Hunter Dixon
    @Dino 64 Do you have any pictures from the backside on how you mounted these to the lower panel? Picked up a set this past weekend and curious on how people are running these.
    Thanks!
  23. Dino 64
    Dino 64
    from Virginia
    The black brackets hold the ***embly on the body, one is a simple u shape, the other is like the toe of a shoe that holds the end. These are original parts, no repo’s that I know of. IMG_6286.jpeg IMG_6283.jpeg IMG_6281.jpeg
