Technical Help with 59ab dist install
Discussion in 'Traditional Hot Rods' started by exc400, Feb 21, 2023.
  1. exc400
    exc400
    Gents, tried to post earlier but not sure it went in. I’m building 32 framed fenderless hot rod, 46 rear, 39 trans, 40 front axle, have it rolling now, about to try and fire the engine (59ab) , it’s “supposed” to run good. It was abate engine so I have rounded up carb, fuel pump, distributor, etc from a 59 I already had. But points, condenser and crab cap conversion and timed it per Vanpelt guide. I have the #1 post at tdc, when I install the distributor, do I just rotate it till it mates with the slot in the cam? Will the rotor then be pointing to wher #1 plug wire will go? Thanks in advance, Wayne
  2. exc400
    exc400
    Should have been Bare engine. Dang spell check
  3. Model A Gomez
    Model A Gomez
    The tang on the distributor is slightly offset as is the notch on the cam and will only fit one way.
  4. alchemy
    alchemy
    And, you do know that a flathead Ford's number 1 is the front right, right?
    LOU WELLS and Desoto291Hemi like this.
  5. 38bill
    38bill
    from Minnesota
    The safe, easy way to mount your front mount dist is to cut the heads off a couple of bolts to make studs that fit the dist mounting holes and screw them in. Then slide the dist on the cut off bolts/studs and gently turn the rotor until the shaft meshes with the offset tang. Then replace the studs one at a time. Makes it basically impossible to get it clocked wrong.
    warbird1 and rusty valley like this.
  6. exc400
    exc400
    Thanks to all who responded. Sounds like I’m on the right track here, just wanted to make sure. Thanks again! Will let you all know when it runs.
