Hot Rods Help with a 30/31 ford roadster
Discussion in 'The Hokey Ass Message Board' started by brady1929, Jan 14, 2024.
  1. brady1929
    brady1929
    Hello,
    What's all involved in installing subrails to a 30/31 ford roadster body? Any special tools required? Is it difficult? Thanks.
  2. brady1929
    brady1929
    Btt. Is this thing on?
  3. wandi harry
    wandi harry
  4. Dirty Dug
    Dirty Dug
    No special tools required, I'd recommend doing it with the use of a model A frame as a base.
    warbird1 likes this.
  5. continentaljohn
    continentaljohn
    All depends on how much of the rails are gone and what part of the body. If it’s in the back trunk area just use a 1932 frame as you nibble away most of it anyways.
    If the roadster needs patch panels then access to subrails will be easier.
    No special tools but Shrinker and stretcher helps as well as Beverly shear
  6. Automotive Stud
    Automotive Stud
    That's kind of a loaded question. What might be easy for you might be hard for someone else. A lot is going to depend on the condition of the rest of the body also. Is there still a rusty subframe in your car? If so there's probably good metal to attach new rails to. If not it's going to get more involved. When I did mine I put everything together with self tapping screws and made sure everything fit good before welding anything in. I'd highly suggest that, I had one tab off by a half inch and the whole quarter panel was bowed out. Easy adjustment when it's just screwed together.
    continentaljohn likes this.
  7. warbird1
    warbird1
    First, check the frame you're going to use for being straight. If it is, bolt the subframe to it with the correct mount blocks and start building the body from front to back. Get the cowl set up properly, then hang the doors, then fit the quarter panels to the doors and work on back...
