Help with a Buick nailhead
Discussion in 'The Hokey Ass Message Board' started by 48silverstreak, Jun 17, 2004.
  1. 48silverstreak
    48silverstreak
    I have a Buick nailhead and I am trying to find out if it is a 364 or a 401 It came out of a 57 Buick century but it is not believed to be the original engine. The casting # on the heads are 1172889. Other than that are there any tell tale signs to what this might be?
    Thanks
    Rob
  2. BLAKE
    BLAKE
    Try here... per this page, that casting refers to 364/401 heads. Measure across the intake bolts holes to tell a 364 from a 401 block - 401 is 9-1/8" while 364 is 8-7/8".
  3. trey
    trey
    [ QUOTE ]
    [/ QUOTE ]
    use that link above with the numbers on your block.
    trey
  4. TagMan
    TagMan
    Rob,
    That casting number was used on both 364 & 401 heads in '59 & '60.
    What's the number stamped upside down (when viewed from the front) on the block casting, just in front of the front edge of the valley pan ??
    -Bob
  5. trey
    trey
    if it starts with 117, use that number.
    trey
  6. Crestliner
    Crestliner
    That casing is for
    59-63
    64-66 8-401, 8-425
    Special 65-66
    Grans sport 8-400
    also states 57-58
    This casting was used alot, but different valve sizes
  7. 48silverstreak
    48silverstreak
    The # on the block appears to be 214475 its a bit hard to read.
  8. Fraz
    Fraz
    from Dixon, MO
    Look on the valley pan lip, right behind the timing cover. There should be a group of numbers there. Get the ones that look upside down.
  9. 48silverstreak
    48silverstreak
    Well the numbers I have are
    Production Code: 214475
    Engine Code: 4D203I followed by I5I
    Thanks Guys
  10. leadsleadolds
    leadsleadolds
    measuring between the bolt holes on the intake is the easyest way they used so many different casting numbers and they still dont have all of them on the buick web sites my vote is with the measuring between the bolts.
  11. 48silverstreak
    48silverstreak
    Thanks for all your help guys,
    I was able to find out that i have a 1957 364CI Buick nailhead.
    Thanks once again for all your help
    Rob
  12. zman
    zman
    from Garner, NC
    Still agood motor and they clean up real well.
