Help with a model A rear end axle!!
Discussion in 'The Hokey Ass Message Board' started by ratamahata, Dec 1, 2010.
  1. ratamahata
    ratamahata
    from Argentina
    Hey guys, Im rebuilding my rear end axle on my model A and when pull out the torque tube all is came out: the drive shaft and the pinion bearings with the cap.
    I think this double bearing cap spinning into the banjo hole... is any chance to put loc***e for fix the cup into the banjo hole.
  2. ratamahata
    ratamahata
    from Argentina
    Please anyone reply!! Thanks!!
  3. Gigantor
    Gigantor
    I don't know, my friend. I don't understand your question. Sorry.
    Maybe pictures would help explain to get a better answer? Bump for your question anyway.
  4. tb33anda3rd
    tb33anda3rd
    green Loc***e?
  5. harald
    harald
    Loc***e makes a bearing retaining compound,comes in the same little bottle as the thread locker. Used it on one of my woodworking tools that had the bearings too loose,works good.
  6. ratamahata
    ratamahata
    from Argentina
    thanks guys!!
  7. ratamahata
    ratamahata
    from Argentina
    In the second pic the pinion armed with the two bearings in the double bearing cap, the other pic is the hole where the pinion goes.
    Originaly this double bearing cap is put in the banjo hole using a press, but in my case the double bearing cap enter in the hole without force, using my hand, I think this double cup bearing spinning into the banjo hole and this is not right...
    I think use a loc***e is a good idea? What you says guys!
    Uploaded with ImageShack.us
  8. F1 Flathead
    F1 Flathead
    from Michigan
    I used it once on a wheel bearing race that had spun in the hub. It seemed to work, as long as the bore is not worn excessively oversize. If it is, your gear alignment will be off and you'll never get the gear pattern right. Was the pinion bearing siezed? Did you replace it? I think you need to be sure you understand why it lost it's press fit in the first place. Dan
  9. jetmek
    jetmek
    those housings are plentiful around here. dont know about your situation but id replace the housing
  10. thats not a model a axle housing
    that could be your problem
    tk
  11. ratamahata
    ratamahata
    from Argentina
    Yes I now that is not a model A axle housing is only for example!!
    The axle housing did not have a excessively oversize. Its fit just but without force...
    If i change the axle housing, I will must bought an early 28 axle housing, by the judging standars.
  12. ratamahata
    ratamahata
    from Argentina
    I have in my own junkyard another model A rear end axle but is a 1930. the are three type of ford model A housings.
    Banjo housings are all functionally interchangeable. The only consideration is the judging standards. There
    are three distinct versions. The first and very early ones have no reinforcement gussets at the front flange,
    and the drain and fill holes are in line in the center of the housing. The second has reinforcement gussets,
    and the fill and drain holes are still in line. The third, and later banjo has reinforcements gussets, but the fill
    hole is offset to the left. Consult the judging standards to determine what year and month configuration is
    correct for your car. The early banjo housings without support gussets are prone to cracking.
