help with a painless 5.0 injection conversion harness
Discussion in 'The Hokey Ass Message Board' started by 59 brook, Aug 7, 2010.
  1. 59 brook
    59 brook
    hi i got the 5.0 to run in my 59 but after a few seconds the fuse which feeds power to the relays and computer burns up . i didn't buy the harness new but it was never installed before i got it just had the box opened. anyway the main fuse for this is currently a 5 amp a freind of mine says thats why it's blowing. anyone know the correct size? thanks
  2. brigrat
    brigrat
    from Wa.St.
    Don't know much about the Painless but Street & Performance and Howell are both 15a depending on circut, usually the fuel pump relay is stand alone 15.....................
    I find it hard to believe you only have one fuse............
  3. 59 brook
    59 brook
    there is a small fuse panel with a 15 and a 10 amp for the fuel pump relay's this is the main power which feeds that fuse panel and the comp power
  4. reece
    reece
    from NC
    I think I recall using a 40 or 50amp Maxi-fuse...
    Is this a 5.0 Ford we are talking about or a 305 Chevy with TPI?
  5. 59 brook
    59 brook
  6. HighSpeed LowDrag
    HighSpeed LowDrag
    from Houston
    What's the part # on the box? You can go to the Painless site and look it up if you know the part #.
  7. crewchief888
    crewchief888
    from NW indiana
    drop an e-mail or call painless, they've always answered even my dumbest questions.
    :eek:
  8. There is 3 7.5 amp, 2 10 amp, and 3 15 amp fuses in the panel.
