Help with a VIN / Title Question
Discussion in 'The Hokey Ass Message Board' started by Ltlgto, Jan 13, 2010.
  1. Ltlgto
    Ltlgto
    I hope you guys can help me (the seller) and the buyer of my '38 Chevy Coupe.
    I sold a 38 chevy coupe after my son owned it for about 1 1/2 years. It was a project and never checked the ***le against the cowl tag. Apparently the guy in Oregon who bought it noticed the difference in numbers and is freaking. The OR. DMV can't find anything info on either number. He wants to bring the car back for his money back.
    I think he seriously wants to keep the car but is afraid to try to get it ***led. The ***le is from Washington and in the name of the owner that my son bought it from. The ***le was from 1992 so he'd had it for about 17 years. I've been told that the number on the cowl tag is not a VIN number but a serial/motor number? The likelyhood of the motor being changed and having to get a new number is highly likely.
    Anyone in Oregon have a problem with ***leing an older car with mismatched ***le #'s and tag #'s ? What is the next step this guy can take? He wants to keep it and I was planning on picking up another car this weekend with his money.
    DMV's can really **** some times!
  2. Well, it should be simple enough to compare the number on the ***le to the motor numbers for 1938 Chevrolet, and answer that part of the question.
    You might try a search for Oregon + ***le, I think this was posted about not too long ago and wasn't that hard to get Oregon to issue a VIN and re***le the car. But I could be wrong.
  3. HELLBILLY
    HELLBILLY
    I was in the same situation as you, bought a car from a friend, never looked at the numbers........... guess what lol
    BUT....... I was able to get it worked out with the DMV.
    Now here is the BIG thing... if you cant get the ***le.... give the guy his money back.
    ITS THE ONLY THING TO DO...... life wont end, he will be happy and you will be a stand up guy.
  4. Ltlgto
    Ltlgto
    HELLBILLY, I completely agree. If he brings it back, I'll give him his money back. A few people I've talked to tonight said it's typical for a car this age to have a different number on the ***le, since it has likely had the motor replaced and a chaenge of ownership since. I don't see this as a problem, but it can depend on what DMV you are working with.
    Hopefully it will work out, because I was supposed to be picking up a '56 2dr. 210 Sedan. Very good shape. 327 and Super T-10 4 spd comes with it.
  5. shock733
    shock733
    from Florida
    I had a new plate made to match the numbers on the ***le of a 32 Ford pickup I had years ago. I mounted it on the firewall. I don't think the 32's came with one but there were NO numbers any where else on this rod. None on the frame, body or doors and the drive train was not original. The ***le was clear for me to insure, register and when I sold it the buyer had no problems. DMV never saw the car only the paper work. Could this be a solution or was that wrong?
  6. redo32
    redo32
    Like most states Oregon has good DMV offices and bad, or maybe I should say intelligent and not so. sometimes the dummies will run it thru and not notice anything amiss. Sometimes the better guys will know their stuff & breeze it thru. Years ago a buddy bought a nice '39 Chev from the second owner in Washington & the DMV wouldn't accept the ***le even though all the numbers matched. They ***igned a Blue sticker with new numbers. Today some buddies swear it is easier to get a new street rod registered with receipts for all the major componets. If the new owner doesn't want to try & convince the DMV that it was originally registered with engine # ( DMV or State Police should have a manuel telling them where the #'s are and which states used engine # instead of serial #) he could do as shock 733 suggests and pop the cowel tag off & make one that matches the ***le #. Bill of sale from your son & the previous owner will help because the car is still in his name & DMV likes a paper trail.
  7. gimpyshotrods
    gimpyshotrods
    I can't speak for any other state, but in CA, that would be a felony.
  8. 38Chevy454
    38Chevy454
    1938 Chevy did use the engine number as the VIN. Cowl tag is NOT the VIN. It *should have been* changed on the ***le if a different engine was swapped in the car, but back then who knows what happened. Or with no engine, there is not an easy to find and see number. Become creative and find the number on the frame.
  9. TooMany2count
    TooMany2count
    from Cahokia,IL
  10. patrick66
    patrick66
    IIRC, the '38 Chevy VIN location should be on the P***ENGER side "A" post, below the upper door hinge, like the '41-'48 Chevy cars. Might be wrong here, but CHECK and see if it is there. Can't hurt!
  11. papastoyss
    papastoyss
    I got into this same situation w/a 41 chevy coupe. An old restorer told me the cowl/firewall tag was a body # not a vin #.
  12. patrick66
    patrick66
    A 1940 special deluxe vin plate is located under the front p***enger side pan, below the door. It is riveted in. Just carefully pull back the mat, and check about halfway in the middle of the door. Check there.
  13. Ltlgto
    Ltlgto
    Well, the 38 is coming back tomorrow and I will refund the money. Hopefully the owner of the 56 will let me put money down or all the money and let me pick it up after the 38 sells again. I will also be looking for another location on the car for a number that matches the ***le or find out what I can do through the Washington DMV to get this resolved. Thanks for the suggestions and help.
  14. 29nash
    29nash
    from colorado
    On chivvys, the number on the cowl tag is body serial number. That is not normally the number on the ***le.
    On chivvys of your vintaqge, as patric66 states, the number on the ***le will be the original motor serial number, also on a tag inside the p***enger side of the car under the floor mat, or on the seat frame. It will also be somewhere on the frame of the car, hidden when the body is in place, of course.
  15. Ltlgto
    Ltlgto
    Thanks 29nash, I will check those places when the car comes back tomorrow. This is a project car and the only interior I have is the original bench seat (in very good shape) so the floor is bare.
