Help with Automatic trans
Discussion in 'The Hokey Ass Message Board' started by swedemike, Feb 16, 2006.
  1. swedemike
    swedemike
    from Sweden
    need help with auto trans
  2. 53sled
    53sled
    from KCMO
    Powerglide? Iron case? Does it not fit? Looking for an adapter? Parts?
  3. yorgatron
    yorgatron
    maybe you should say what KIND of trans and what's WRONG with it,before the norwegians show up and start making fun of you :D
  4. 53sled
    53sled
    from KCMO
    Its kind of late for them, now its almost midnight over there. And it has been dark since october right? maybe its getting to him:D
  5. OK, first you need to remove it to determine if the flubberguster bearing is wingeing. This will cause that banging noise on decel.
    If that's OK, then check the torque converter for weight. It's has some?? Good.
    Now throw everything into the nearest dumpster and find yourself a REAL transmission, one with actual GEARS and a stick-like thingie to move them.
    Cosmo
  6. Yo Baby
    Yo Baby
    Now that's what I call a vague description of a problem.LOL
  7. HEATHEN
    HEATHEN
    from SIDNEY, NY
    I just checked out my magic 8-ball, and it said that the second gear sprag is at fault.
  8. stealthcruiser
    stealthcruiser
    I have to call you on that,Heathen.
    sounds like the annacannapannastan needs to be lubed,knurled,and
    gnarled.
  9. chopzuk
    chopzuk
    from central AR
    OK. First check the blinker fluid.
    Next, tighten the kanooter valve.
    Now, put a little grease on the muffler bearing.
    Should be good to go, but if you need any more help, just PM
    Dr. Stickimdeep, and I'll be glad to help.:D
