Technical Help with Cam identification
Discussion in 'The Hokey Ass Message Board' started by 31hotrodguy, Feb 2, 2021.
  1. 31hotrodguy
    31hotrodguy
    Yesterday I picked up a 301 Chevy from a fellow hamb member.
    We got it torn down today and I’m trying to figure out what the cam is. I tried doing a search and haven’t come up with any thing. Does anyone have any info on these numbers? IMG_4365.JPG to me it looks like an Erson cam??
    bchctybob likes this.
  2. 31hotrodguy
    31hotrodguy
  3. 56sedandelivery
    56sedandelivery
    Erson phone number:1-800-641-7920. Or online: pbm-erson.com/ContactUs. I've got an old, but NOS Erson cam that I had to contact them to find out the specs. Turned out it was a really MILD hydraulic grind, but it'll probably be a good cam for my 265 build. I am Butch/56sedandelivery.
    31hotrodguy likes this.
  4. 31hotrodguy
    31hotrodguy
    Thanks for the phone number Butch. I’ll try and give them a call this afternoon.
    Scott
  5. lumpy 63
    lumpy 63
    Hey Scott , is the rear cam journal grooved? Just curious to see if its correct for the 57 block.
  6. egads
    egads
    1974 Erson catalog : DSC00253.JPG
  7. lumpy 63
    lumpy 63
    Looks like part # 115711:D
    egads and Budget36 like this.
  8. Budget36
    Budget36
    Sure does.
  9. v8flat44
    v8flat44
    Ya never know, back in the day i had a 283 & no one could adjust the valves corectly. An older Mopar racer got the # off of it and sent it to a Chevy guy. Turned out that the cam was one of 3 special Duntov cams that "got lost" at G M. It had been used in a sprint car in Fremont Ohio before in ended up in my 58 Vette. ??? Go figure.
  10. 31hotrodguy
    31hotrodguy
    I think you are thinking of the early 265’s like 55. I think even 56 is not groved. I could be wrong though.
  11. 1-SHOT
    1-SHOT
    from Denton
    I ordered a cam thru Friendly Chevrolet that Smokey gave me the # when I went back a couple of months later to order another one they told me that was not a good part number, go figure it out.
  12. 31hotrodguy
    31hotrodguy
    That looks like a winner! And would makes sense with the cast Jahns pistons. Anything too radical and those pistons might have come apart. I think it is going to be a fun little engine to rebuild.
    Scott
    bchctybob, Tickety Boo and egads like this.
  13. 56sedandelivery
    56sedandelivery
    Jahn's cast pistons were sure popular "back in the day". I have a STD bore set for a 265 Chevrolet, flat-tops with two valve reliefs, and they are polished (first set of those I've seen). They are NOS, but not in the original box; that box basically disintegrated with time. They'd be perfect for a Junior Stocker type build. Only 55-56, 265's utilized the rear cam journal notch, that provided pulse oiling; 57's came with the improved, full flow oiling with both the 265 and 283 engines. I think as long as you use "as good of gas" as you can find, have your quench set up correctly, and don't lean to hard on advancing the timing, those pistons should be fine; detonation is the enemy there. Too bad that "301" did't have one of the Hi Flow cams in it. What heads, if any are on it? I am Butch/56sedandelivery.
    31hotrodguy and lumpy 63 like this.
  14. 31hotrodguy
    31hotrodguy
    Butch, No heads, just a short block but I have a set of camel backs that will probably end up on it. It will be a poor man’s build a d give me time to finish my “nice” engine for the 55 g***er.
    Scott
