Technical Help with Carburetor/No Start issue
Discussion in 'The Hokey Ass Message Board' started by BigBoltChevy, Jul 24, 2018.
  1. BigBoltChevy
    BigBoltChevy
    In the 6+ months, with less time available to tinker than I'd like, I still have not gotten it started. The other carb was in bad shape, so I bought a NOS one. Here's a video of my attempt to get it to run. Its cranks and fires up, but wont continue running. I'm waiting for an electric choke to arrive thinking it really needs a choke to start, but take a look. The H.A.MB has been incredibly helpful for the beginners like myself.
    Link to Video (too large to post):
    Sent from my SM-N950U using The H.A.M.B. mobile app
  2. greybeard360
    greybeard360
    One thing I noticed was the washer on the front carb stud bouncing around under the very loose nut. Can be a big vacuum leak. Also when cranking it sounds like it is kicking back a little... Too much initial timing.
  3. manyolcars
    manyolcars
    95% of carb problems are electrical. Is your ballast resister bad?
  4. Bandit Billy
    Bandit Billy
    That's a pretty hard crank, you sure you got that distributor in right?
    Had it ran previously, sorry if I missed that somewhere
    BigBoltChevy likes this.
  5. '49 Ford Coupe
    '49 Ford Coupe
    HUGE vacuum leak.. why don't you tighten that loose stud/retainer on the driver's side of the carb..??? I bet she will run just fine then
    Unkl Ian and BigBoltChevy like this.
  6. landseaandair
    landseaandair
    from phoenix
    Washer is being blown upwards by the exhaust gas p***age in the front of the baseplate for warmup. Definitely could be a major vacuum leak as well as pressurized exhaust getting in.
  7. oj
    oj
    Is it quitting when you release the key from 'Start' to 'Run'? Seems to my you pump gas, engage the 'Start' and it starts while you continue to pump and have by then released the key from 'Start' to 'Run' and even though you still pump gas it shut off. The wire from the 'Run' (ignition) is broken, it is starting because the wire from the starter solenoid is feeding the coil but when the strater solenoid opens the voltage goes away and the coil has no power. Try to run a wire from the battery to the coil and I'll bet it starts and runs, remove the wire to shut it 'Off'.
    tb33anda3rd and BigBoltChevy like this.
  8. Truck64
    Truck64
    from Ioway
    Good advice above. It does sound like the timing is off one way or another.
    Start with the basics. Did you check for a good hot spark? Verify #1 piston TDC with a piston stop and that this jibes with the "0" timing mark on the damper. Make sure the plug wires are in proper firing order, and the distributor is stabbed correctly, and the rotor points to #1 terminal. These are all very common errors or engine derangements.
    Not trying to beat up on you here, but show some mercy on the starter, solenoid and battery lol. An engine that won't light off will quickly burn up a starter and solenoid, they are really only designed and built to operate for just a second. Allow at least a minute or two of rest for every second of cranking. Starter might not fail right away but extended crankfest will severely reduce its service life. Put the battery on a charger overnight, too.
  9. KoolKat-57
    KoolKat-57
    from Dublin, OH
    With the gl*** fuel filter banging against the valve cover, the loose carb will be the least of his problems!
    KK
  10. Truck64
    Truck64
    from Ioway
    Those filters are notorious for starting fires.
    As a general rule, it is a good practice to keep a fire extinguisher ready and available.
    One easy test for over-advanced ignition timing, disable the ignition by grounding the coil wire. See if the engine turns over freely.
  11. 302GMC
    302GMC
    from Idaho
    If somebody sold that carb as New Old Stock, they committed fraud ...
  12. Oh my !:(
    54vicky likes this.
  13. '49 Ford Coupe
    '49 Ford Coupe
    No offense, but he just can't be helped
    54vicky and Unkl Ian like this.
  14. bobss396
    bobss396
    Loose carb and that filter has got to go. How much fuel is in the filter? You may want to do a quick fuel pump volume test, look it up. An electric choke won't be much help and the 2GC has a pretty good choke, get the parts to get it to work. Once you get that far, try retarding the timing as it cranks.
    54vicky likes this.
  15. BigBoltChevy
    BigBoltChevy
    Thanks! I plan to go through all the recommendations.
    Bandit Billy likes this.
  16. BigBoltChevy
    BigBoltChevy
  17. BigBoltChevy
    BigBoltChevy
    Thanks! I plan to go through all the recommendations. Yes, the shipping company drove it onto the truck when being delivered to me. The starter was cracked once it arrived, and I had the hardest time getting any action out of it. Once I was able to figure out the starter was cracked (After I replaced some of the cruddy wiring), I then moved on to the next "thing".
  18. BigBoltChevy
    BigBoltChevy
    Yep, I have my fire extinguisher ready and available, and I keep a wet towel around when I've tried to use prime the carb to get it to start. Great suggestions that I previously saw in another posting on the H.A.M.B.
    Truck64 likes this.
  19. BigBoltChevy
    BigBoltChevy
    Could've been lying to me!!! But it's a LOT better than the one that was on it.
  20. BigBoltChevy
    BigBoltChevy
    Will be doing this also. Thanks for taking the time to provide recommendations. The other 3 are tightened well, but this 4th is in a place that's nearly impossible to get to. I was obviously wrong to thinking it perhaps didn't matter.
  21. BigBoltChevy
    BigBoltChevy
    Thanks! Many of you are recommending to get rid of the filter and tighten down the 4th stud on the carb. Plan to do both those first. The carb utilizes a hot air choke. I'll do some more homework to see if I can figure out what the connections look like/required to go that direction. The carb I removed was in pretty bad shape, and didn't appear to be the one that was on it for the year. Thanks a bunch.
  22. BigBoltChevy
    BigBoltChevy
    You're insight is very helpful. Thank you. The starter/solenoid was my planned "next" issue to address once I got it started. This a "NOS" solenoid as the last one was cracked and stopped working all together. When I turn the key, sometimes it just "spins". that's just to say, I can hear what sounds like the starter just spinning, without engaging the flywheel. So I have to "bump it" sometimes until I hear/feel it engage. Then It attempts to start. I know this has to be addressed/resolved, and planned to start trying to figure things out after this non-starting issue. Again, thank you so much for your advise. You and the other members who take the time to provide constructive feedback/recommendations is INVALUABLE. I hope over time, I'll be able to gain the knowledge that I may share with someone later as well.
  23. Unkl Ian
    Unkl Ian
    Carb isn't bolted down properly.
    ****ty fuel filter is a fire waiting to happen.
    What other half ***ed ******** is going on ?
    Quit ****ing around.
    54vicky likes this.
  24. ClayMart
    ClayMart
    In your video it looks like the choke is trying to close after the engine starts. If this is taking place in Texas somewhere, I'd guess there really isn't much need for the choke once the engine starts running. It may be flooding the engine nearly as soon as it starts. Before throwing any money at the choke, study the choke linkage and try to figure out a way to wire the choke valve open, temporarily at least.
    This will at least give you a chance to get the idle speed and idle mixture somewhat adjusted. And save your battery and starter a bit of extra stress.
    Some folks might say to just prop the choke open with a screwdriver but there's always a chance of it dropping too far down in the throttle bore and also propping the throttle plates partially open.
    54vicky likes this.
  25. thomas.parker197
    thomas.parker197
    That choke should be hooked up to the exhaust manifold, couldn't tell if it was or not. I would definitely wire the choke opened. May want to check the online manual for that early rochester 2gc. It mat indeed be NOS, but is almost certainly remanfactored. Have you set the idle mixture screws?
    Sent from my SAMSUNG-SM-G900A using Tapatalk
