I have a 34 ford sedan that I am putting a five inch chop on and the problem that I am having is the body line that goes from behind the rear side window to above them and then on to the front of the car. The body line is fat at the bottom then skinny at the top, I am wondering how to make a smooth transition. This is my first chop and I am only 20, I have little help if any so any help at all is appreciated. Thanks.
In general you need to make the wide one skinnier and the skinny one wider and then fill the gaps. Haven't done that particular model before but that is the technique to get them to flow together. Charlie
