Technical Help with custom grille ID - Hope to NOT stump the HAMB
Discussion in 'The Hokey Ass Message Board' started by Barn Hunter, Apr 26, 2020.
  1. raylloyd
    raylloyd
    I wonder what the mounting holes in the grill look like. I would think if it was 1 piece there would be two in the center piece and on at each end of the spears. If the center piece and spears are separate I would think there be two holes for the center piece and then holes at both ends of each spear .
    Barn Hunter and Moriarity like this.
  2. raylloyd
    raylloyd
    stillrunners and Barn Hunter like this.
  3. Hnstray
    Hnstray
    from Quincy, IL
    At first I thought it could be ‘55 Buick grille trim. Not so sure about that now, but I have one at my shop. Will dig it out and compare.
    However, I am sure it is a Buick piece......front or rear. Will keep looking...
    Ray
  4. Moriarity
    Moriarity
    SUPER MODERATOR
    I think it looks buick too but I scaled a photo of a 55 buick and it looks like the part in question on the buick is over 30 inches long. I scaled the old photo of dominique using a headlight as a guide and determined that the bar is 21 inches long and the ctr is 3 1/4 " in diameter. I think @Barn Hunter measured the opening in the car back on page 1 and the opening is 28" wide
    Barn Hunter and kidcampbell71 like this.
  5. raylloyd
    raylloyd
    True, but I don't think this particular one is the 55 Buick one.
    55 Buick
    egads, Hnstray and Barn Hunter like this.
  6. Moriarity
    Moriarity
    SUPER MODERATOR
    true, I wonder how big that is..... I wonder if it is aftermarket?
    Barn Hunter likes this.
  7. Barn Hunter
    Barn Hunter
    Thanks, Mark.
    Moriarity likes this.
  8. Barn Hunter
    Barn Hunter
    I'll look for a close pic of this one. Maybe.....
  9. Barn Hunter
    Barn Hunter
    Do you own that one?
  10. Barn Hunter
    Barn Hunter
    Thanks, everyone for your efforts. I'll try to get in touch with the owner of that piece to get measurements.
    kidcampbell71 and Moriarity like this.
  11. raylloyd
    raylloyd
    The folks at the AACA forum thought it was aftermarket. If that center piece is 3 inches, eyeballing it makes the spears 9" which puts us at 21". That probably isn't specifically it, but if a company made something aftermarket like that with a Buick emblem, what else did they make like that. Might be worth trying to find a 50's JC Whitney catalog and flipping through it. Maybe its aftermarket and thats why in the article he just said he found it in a junkyard and didnt mention off from what.
  12. Barn Hunter
    Barn Hunter
    Here is a pic of the mesh part of the grille. When I got it, it had 2 small teardrop trim pieces (not original). You can see the ghost image on the close up. The original holes in the mesh are shown as 4 5/8" apart and are right in the center. There is another hole just to the right of the right hole. I believe that one is not original. There are no other holes in the mesh. 20200427_154140 (2).jpg 20210113_112514 (2).jpg
  13. Squablow
    Squablow
    I have a 1958 Almquist catalog that I looked through but I didn't see any of these grille bars, although I think a JC Whitney or Honest Charlie's would be a better bet to find stuff like that. Almquist didn't have a whole lot of custom stuff in it.
  14. Moriarity
    Moriarity
    SUPER MODERATOR
    I just paged thru my 1962 JC Whitney and did not find it, found a bunch of other great things though....
  15. raylloyd
    raylloyd
    Then it would have to be one piece I would think, I have kind of been thinking the spears have been separate. Maybe the spears could go over the centerpiece and hold it down, but you would think there would be some mounts at the end, like this picture from a 57 Buick emblem. The second pic is a 15 inch old fridge badge. Even that has 4 mounting pins.
    If its all one piece that makes it less likely something he made and more likely something he found right?
  16. Barn Hunter
    Barn Hunter
    I agree it would be a 1 piece unit. With the mounting studs of the aftermarket piece shown above, it looks like an even more likely candidate. That piece looks like it's aluminum so it probably wouldn't need studs at the ends. I think we're pinning it down.
  17. Magfiend
    Magfiend
    Barn Hunter and raylloyd like this.
  18. raylloyd
    raylloyd
  19. Sandgroper
    Sandgroper
    I think you got it :):):):):)
  20. Budget36
    Budget36
  21. Barn Hunter
    Barn Hunter
    raylloyd, Johnny Gee and Moriarity like this.
  22. Squablow
    Squablow
    I think raylloyd has it here! The hard part might be finding one, but damn, that sure looks like it.
    I'm finally going to be able to sleep. Thanks raylloyd!
  23. raylloyd
    raylloyd
    You and me both! Has to be it.
  24. Johnboy34
    Johnboy34
    from Seattle,Wa
  25. Squablow
    Squablow
    After seeing that overlay comparison, I'm convinced, every proportion is right, and also the advertised width is so close to the scaled estimate.
    And that would still track with the builder's story of him finding it in a junkyard. Somebody with an older car could have bought one out of the catalog, stuck it on their car, maybe to dress up an old, used car, then the car either got wrecked or just junked from age, when the builder stumbles on it in the yard. Honestly, the builder might not have known it wasn't a factory part if he pulled it off a wreck in a junkyard.
  26. Barn Hunter
    Barn Hunter
    raylloyd likes this.
  27. Squablow
    Squablow
    I also found this on the internet, hard to tell if that's the same piece as the better picture or not, but figured I'd add it just in case, the JC whitney part numbers might be useful for searches. This catalog was marked 1955 #112 by whoever posted the pic.
  28. SR100
    SR100
    Unfortunately, that isn't it. When I look at the blowup @raylloyd posted, the spear is one piece, notched for the center section. The other problem with is that the roundel in the center is too large. If the spear is roughly 21-22", the roundel can't be 4", which the catalog piece is.
  29. raylloyd
    raylloyd
    You may be right, its really hard to be certain based on the quality of the pics. But I personally feel really really good that this is it. Like Squablow said, it fits the story in the article. I am not good with photoshop, but below is the only pic i could find of one on a car. I really think it is it, and the look of the blown up one is just reflections and shadows of a low quality photo being blown up.
  30. kidcampbell71
    kidcampbell71
    Maybe there is a dusty shelf, in LaSalle, Illinois .. .. with a dirty, torn package .. containing a Motoramic JC Whitney No. 14179 bomb sight spear grille bar ?
    Or .. .. maybe there isn't.
    I too .. feel good that the mystery is solved, but now a new mystery evolved. Where would one obtain such a quinky dink item today ?
    Moriarity, Budget36 and Barn Hunter like this.
