1952-59 Ford Help with door glass run replacement
Discussion in 'Off Topic Hot Rods & Customs' started by Paul Selfe, Jun 20, 2014.
  1. Paul Selfe
    Paul Selfe
    Hi Guys, I'm trying to replace the gl*** runs in my 56 two door. My manual explains how to remove the division bar without taking the gl*** out, but I'm wondering if you can remove the rear gl*** run with the window still in place. Anybody out there have experience with this, or any tips to make the job not look like a real PITA. Thanks, Paul Selfe.
  2. ctfortner
    ctfortner
    from West TN
    I am certainly not an expert on this one, but I am currently doing it on mine. I tried to figure out a way to replace it without removing the gl***, but I just didnt see how it was going to work, at least easily. Now, I am not installing factory channels either, so mine dont have the clips to pop in place, I am 3m weatherstripping my new channels in. I removed the clips to the rollers and got the door gl*** out pretty easily by myself. Went ahead and took the vent out also, it needs some work. I got one side glued in, but havent reinstalled the gl*** yet. While its out I am working on other things.
    Here is a thread I had about it that you may find useful
    http://www.jalopyjournal.com/forum/threads/window-channel-install.919203/#post-10393346
  3. rick55
    rick55
    I bought replacement gl*** door runs with the clips installed including the rears and am now of the opinion they are more trouble than they are worth. For the rear quarter windows I ended up taking them off, gluing them and pop riveting them into place. I retained the clips on the front windows.
    I believe TeeBird Products have the rears with clips installed and prebent but shipping would be more of a problem than the straight ones I bought. I then found a better quality generic bailey channel here in Oz a whole lot cheaper but I already had them installed by then.
    You need the gl*** out to get bailey channel support brackets out and glued onto the bailey channel. The gl*** is not that hard to get out if you follow what the manual says and watch the lower gl*** supports as they come up through the window opening. You just have to manoeuvre them to clear on the way out.
  4. Paul Selfe
    Paul Selfe
    ctfortner, Thanks for the thread, I think it will be helpful. I don't have the replacements yet so I'm taking my time with this. Paul Selfe.
  5. Paul Selfe
    Paul Selfe
    rick55, I think I will remove the gl***, I want to clean and lube the rollers anyway. I already removed the division bar and vent on one side, that wasn't too hard, even for a guy suffering a bad case of Sciatica. Thanks for your input. Paul Selfe.
