Technical Help with finding alternative to the 3 speed Muncie in Automatic
Discussion in 'Traditional Hot Rods' started by katyfattrodder, Apr 25, 2023.
  1. katyfattrodder
    katyfattrodder
    Hello all wanting to see if anyone has experience swapping out a Muncie 3 speed with an automatic? I'm cramped for space so looking for something similar in size if anyone has done this swap before.
  2. Would help to know what car it is in, and what engine it goes behind. ***uming looking at a GM automatic, my suggestion would be to measure the room available and check out the GM automatic dimension chart that is on-line from many sources.
    katyfattrodder and LOU WELLS like this.
  3. squirrel
    The TH350 is pretty close in size to a Muncie 3 speed. Same length, mount location, and driveshaft spline, too. You'll need a different shifter, a transmission cooler, a kickdown cable, etc.
    Like he said, we can't see what you can see.
    Tim, PONTNAK123, SS327 and 1 other person like this.
  4. 57 HEAP
    57 HEAP
    Powerglide and 200R-4 would be simular in size as well.
  5. katyfattrodder
    katyfattrodder
    thanks that is one of candidates.............
  6. katyfattrodder
    katyfattrodder
    its going into the roaster you see in my avatar. has a hemi but doesn't matter would need an adapter. looking for similar size as i have no room to go bigger
  7. ekimneirbo
    ekimneirbo
    from Brooks Ky
    Transaxle........
    jaracer likes this.
  8. squirrel
    The TH200 is probably the smallest, but they're hard to find. The 200-4R is significantly larger, the "guts" extend back a lot further.
    Pretty hard to see your floor from here....
  9. SS327
    SS327
    Th200 is a piece of junk. Avoid at all cost.
  10. squirrel
    turns out they're a strong transmission, IF you spend some dough fixing it up. Ask the cl*** drag racers...
    Tman and katyfattrodder like this.
  11. Johnny Gee
    Johnny Gee
    from Downey, Ca
  12. lippy
    lippy
    from Ks
    A four speed Muncie or T-10 will fit too. :D
    Bob Lowry and Moriarity like this.
  13. SS327
    SS327
    Still a hard p*** for me. The nightmares, oh the nightmares! Broke a lot of them!
  14. lippy
    lippy
    from Ks
    Just wondering why you want to go with an automatic? Seems a stick in that little roadster would be fun. Lippy
  15. katyfattrodder
    katyfattrodder
  16. JimSibley
    JimSibley
    I did that swap on my 27 roaster. An air cooled powerglide out of a chevy 2 nova. No trans lines, same mount. Just swap the shifter.
  17. katyfattrodder
    katyfattrodder
    thanks for sharing, if OK may bug you once I go down this rabbit hole..........
  18. TERPU
    TERPU
    If it's getting stuck the linkage needs adjustment or the Trans is going Bad. Could just be a simple fix.
    An Automatic is no smaller in diameter and if the floor is already this tight you won't gain anything. But you'll lose the ability to row the gears.
    just my 2c from in the dark.
    PS - Automatics are for Customs. You ROWdster through the gears.......
  19. Mr48chev
    That's cute if you have room for a clutch pedal without getting your feet hung up or if your left knee is still able to work a clutch in traffic. My 77 flatbed has a 4 speed and the clutch in that is all my knee wants to handle. I've got a 5 speed for my 48 and am seriously pondering going turbo 350 instead. My 76 year old knee doesn't like clutch pedals like my 40 year old knee did.
    SS327 likes this.
  20. TERPU
    TERPU
    Well, I can't help it if your a Quitter..... ;-) Trust me I understand completely and I am only 50.
    But the point still stands, if it's getting hung up it's a clearance, linkage problem, or worn out parts not inability.
  21. Budget36
    Budget36
    I think some may have missed the OPs additional info. He stated his wife and daughter also want to drive the car and both prefer an automatic.
    I think (could be wrong) he thought maybe an Auto would take up more room than his 3speed, hence he mentioned size/fit.
    Of my 3 daughters I have one that has no want to learn to shift gears. Another is repulsed by automatics.
    Ned Ludd likes this.
  22. 6sally6
    6sally6
    What's it take...........1/2 of an afternoon to get comfortable driving with a manual trans.? o_O
    IF....(big IF!!) my wife ever had a brain-cramp and 'wanted' to drive my M-word hot rod ...
    she could...... When she got comfortable (again) with a manual trans.
    Sorta-like........" I'll gladly smoke one of your cigarettes...if you go buy a menthol.."
    6sally6.........(just stirring the pot fellas)
  23. Bob Lowry
    Bob Lowry
    Hope this helps....actual measurements:
    katyfattrodder and Budget36 like this.
  24. X-cpe
    X-cpe
    If someone doesn't want to learn, there aren't enough hours in a lifetime to teach them. My wife wants nothing to do with a manual trans. It only cost me one trans before I took the hint. On the other hand, it only took one extra hour of drivers ed and my daughter had it down pat. Her first car was an S10 Blazer, 5spd.
    The OP is probably OK in the bell housing area. The trans tunnel will probably have to be enlarged some, especially if his Muncie is a 318, non synchro first gear. Getting rid of one pedal will buy him a little more foot room.
