Technical Help with Gasser Front End
Discussion in 'The Hokey Ass Message Board' started by sedantudor, Feb 5, 2023.
Tags:
  1. sedantudor
    sedantudor
    All,
    I have been working on my first G***er build and have a few questions. First off, the 1952 Ford weighed 3,070 pounds. I was planning on using a vega steering box but just recently found out that the steering box should not be used on anything over 2,800 pounds. The car had a straight six in it and I installed a 454 big block. I removed the inner fender wells, front bumper,.....stc. Not sure if the vega will work. Suggestions would be appreciated.
    Next issue, the front shackle. Obviously it folded over. I was told to move the shackle forward instead of making longer shackles. I completely believe the guy who told me this as he has a lot of experience in building g***ers. Reasoning was deflection while steering. Thoughts?
    This picture is of the tie rod on the p***enger side. I am using a Speedway tube axle with their kit. Is this set up correctly?
    Same questions as above, is this set up correctly? I do not like the fact the threads of the bolt do not come all the way through the steering arm.
    Any thoughts here would be greatly appreciated. Thanks!
  2. Jalopy Joker
    Jalopy Joker
    have you talked to Speedway about these questions?
    SS327 and mad mikey like this.
  3. sedantudor
    sedantudor
    Not yet. On the agenda for tomorrow when I get a chance..
  4. 31Apickup
    31Apickup
    You can use a Saginaw 525 box, bolts to the same mount as the Vega box. It’s a much heavier box. I’d prefer regular tie rod ends over heim joints.
    SS327 and bchctybob like this.
  5. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Eliminate as many of those big spacer bushings as possible. What is that long spacer for? Try to get the Heim end as close to the steering arms as possible. A Saginaw (525???) box like on AMC cars or Chevelles is an option.
    You didn't ask this, but
    a) limit your front caster to seven degrees.
    b) use a steering damper like a Fiero or VW.
  6. 57Fury440
    57Fury440
    I've been running a Ford Econoline front axel for over 50 years. I agree with what 31Apickup said about using tie rod ends. They are not as pretty, but they are very dependable.
    SS327 likes this.
  7. 427 sleeper
    427 sleeper
    What you have is a real mess. Step back and re-think what you have going on.
  8. mad mikey
    mad mikey
    You better start over , from what I see in the pictures :eek:
    All Ford, SS327, Gasser 57 and 2 others like this.
  9. saltflats
    saltflats
    from Missouri
    Hard not to see things I don't like.
    but you want the shackle pointing forward at a 30 to 45 degree angle with weight on the springs at ride height.
    You want the main leaf spring to be able to flatten out and not bind or max out the shackle.
  10. squirrel
    I used a speedway kit, I read the instructions about how to set up the springs....this is what I ended up with. Notice that about half the leafs are gone from the spring, so it actually acts like a spring, instead of a solid piece of steel. When the spring is compressed almost flat, the shackle is at an angle. When the car lifts up (either by jacking the frame...or doing a wheelie at the strip...) the spring gets it's curve back, and the shackle slants a little bit the other way.
    I have the heim rod ends on 3/4 of my steering. They work.I have a tie rod end where the drag link connects to the pitman arm. You do need bolts long enough to get full thread engagement.
    mad mikey, Bandit Billy and saltflats like this.
  11. swade41
    swade41
    from Buffalo,NY
    Here's mine, your shackle definitely needs cut off and redone, I set mine up using the main leaf only and a block of wood to simulate the thickness of the missing spring back. As you can see it turned out right with the weight of the big block tunnel ram combo, also I had the spacer tig welded to prevent any wiggle.
    Give me a few minutes and I'll run out to the garage and take some detailed photos.
  12. swade41
    swade41
    from Buffalo,NY
    Driver's steering arm
    Pitman arm
    P***enger steering arm
    Whole enchilada
    mad mikey, saltflats and Chucky like this.
  13. bchctybob
    bchctybob
    You will need to carefully cut those front spring hangers off of the frame and move them forward about 1.5-2". Use a 525 steering box as others have said.
    Once you get everything fixed and back together, use the spacers as needed to get the tie rod and drag link to clear everything and to be as parallel to the axle as possible. Weld them to the steering arms once you have everything working right.
    The Heim style rod ends are ok but use these seals to help keep dirt and debris out of them and check them often for lube and play. Factory style tie rod ends are better, but your steering arms don't appear to be tapered for them.
    Seals-It WS5001 Heim Joint Rod End Seals, 1/2 Inch Hole, Set/6 (speedwaymotors.com)
    mad mikey and squirrel like this.
  14. squirrel
    hey, I should get some of those seals, and put some oil on my rod ends, eh? They've just been riding out in the breeze all this time, dry. But they're still pretty tight after 30k miles.
    ottoman, SS327, mad mikey and 3 others like this.
  15. fastcar1953
    fastcar1953
    I've never worried about mine and they have around 30,000 miles also.
    mad mikey likes this.
  16. bchctybob
    bchctybob
    The Seals-it seals are really nice and just add a little protection. If your rod ends are in a double shear mount, they probably won't fit since the washer part of them is .048"-.050" thick, each.
  17. we put V8s in Vegas and didn't change the box.
    Or get a mustang box and don't worry about it.
    2OLD2FAST, SS327 and mad mikey like this.
  18. sedantudor
    sedantudor
    Thanks for the advice folks. I am looking at couple of things and plan on making some modifications. Thanks to those who provided helpful advice and constructive criticism. First g***er build, I don't have all the answers. Thanks again.
  19. sedantudor
    sedantudor
    As frenchtown mentioned, I did set the caster at 7 degrees. At least it seems I got something right. Working on the rest. Thanks
  20. seb fontana
    seb fontana
    from ct
    Quality of new seals are ****, fall apart in short time. Have some that are over 20 years old and are still fine.
    2OLD2FAST likes this.
  21. swade41
    swade41
    from Buffalo,NY
    So @sedantudor what happened with your front end ???
  22. sedantudor
    sedantudor
    I got the axle straightened out. Was not happy with the height so I made shackles a bit longer to raise it up a hair. Right now I am working on the ladder bars in the rear. I am still waiting for my drag link to show, got the the steering box installed, and steering column. Hopefully soon I will be done with all of the mock up and ready to pull things apart and start my final welding, put the engine together, and then the trans. Thanks for asking. Will post more pics when I have a few moments.
    bchctybob and swade41 like this.
  23. aircoup
    aircoup
    gotta post some pictures of mine and get some opinions i didnt set it up previous owner did .YIKES !! im just that way with anything i didnt set up it drives fine !
  24. 2OLD2FAST
    2OLD2FAST
    from illinois
    Better to have put blocks between spring & axle than to have lengthened shackles IMO .
    427 sleeper and 1971BB427 like this.
  25. 1971BB427
    1971BB427
    from Oregon
    Indeed!
    Lengthened shackles change the caster, and also can be pretty spooky when making sharps turns at almost any driving speed when they deflect sideways, and cause steering issues. Blocks of 4" or less have been used for many decades without any issues.
    427 sleeper likes this.
